Fuel Delivery problems?
Old Feb 23, 2005 | 09:47 PM
jgteg81's Avatar
My 92 4runner (192K mileage) is having problems during acceleration. Its kind of tough to explain, but when I push the gas pedal in it takes a lot of pressure to get it to accelerate especially at higher speeds. The rpms are jumpy. When I release the pedal just a little the rpms go down and it downshifts quickly. It seems to be getting worse. It idles fine when stopped. It is an automatic. I'm thinking it has something wrong in the fuel delivery system (fuel pressure regulator or injectors). How common is it for these things to give out? Any ideas? I did a tune-up with spark plugs, cap, and rotor and replaced the fuel filter too. I've also had problems with the power steering leaking and going out. I'm replacing the pump this weekend, but don't know how it would relate to the other problem. Any help would be most appreciated. Thanks.
Old Feb 23, 2005 | 10:28 PM
Tacoma Dude's Avatar
I have no experience in this and am by no means a mechanic but I'm wondering out loud (in case any mechanics happen across this thread), could the throttle cable be suspect here?
Old Feb 26, 2005 | 08:50 AM
84sr5yoty's Avatar
I was kinda thinking on the fuel pressure regulator myself. One way to test it is to pull the vacuum line on it while the motor is running and see if it pukes out fuel. This is how they usually fail, the diaphram deterorates.
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
gary4runner
Sep 24, 2015 12:53 AM
shisha1999
Jul 13, 2015 11:09 PM
