Front tire alignment issue?
Old Oct 12, 2005 | 03:06 PM
4Runna's Avatar
Hi all,
After washing my 4Runner this past weekend, I noticed something odd when looking at my grill from about ten feet back. My front tires weren't perpendicular to the ground. They looked like this:
\-----------/ (though not as severe)
Then I got my tires rotated and they said that the outer edge of my tires had slightly more wear than the inner edge.
Is an alignment going to do the trick here?
Thanks in advance...
Old Oct 12, 2005 | 03:09 PM
Flamedx4's Avatar
probably nothing wrong. A slight \----/ is correct.
https://www.yotatech.com/forums/f2/t-bars-down-not-up-69195/
and many many others...
Old Oct 12, 2005 | 03:21 PM
4Runna's Avatar
Thanks Flamedx4. You just saved me some $!
Old Oct 13, 2005 | 02:13 PM
surf4runner's Avatar
check out the ball joint recall for later 4runners.
Old Oct 13, 2005 | 02:56 PM
jimbo74's Avatar
also it could be an alignment issue... no way to tell without checking it first.... if the alignment is out, then doing an alignment will fix it....
it depends on the spec for that vehicle, some of the high performance bmws actually are in spec like / \ they purposely set the tires @ 1-2 degrees negative camber for handling
Old Oct 13, 2005 | 03:32 PM
4Runna's Avatar
I have a 1998 4Runner Limited. I just read up on the recall and it doesn't look like it applies to me.
However, the slight angle of the front tires is bugging me to the point where I must have them "fixed". It may be within spec, but I want them []----[] instead of slightly \-----/
thanks tho!
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
Jun 1, 2021 01:51 PM
87blyota
Jul 8, 2015 09:16 AM
