Front & Rear Swaybar bushings
Old Oct 27, 2003 | 05:48 AM
data's Avatar
Senior Member
Anyone know where to find any? I have called NWOR, but they won't be available until the end of the year. I have looked under the toyota section on Energy Suspensions site, but I didn't find anything.
Old Oct 27, 2003 | 06:33 AM
CTB's Avatar
CTB
When I got my front disco's from Lee, I also got new front sway bar bushings. I've had them for quite a while now, but just been too dang lazy to install them.
Anyway, I'm pretty sure they came from Energy Suspension. Maybe try giving them a call to see what you can find out. I think most of the guys who have added new bushings to their swaybars have gotten them from ES.
Old Oct 27, 2003 | 07:04 AM
ALBPM's Avatar
Actually you can get them at Summit racing
Here's an example:
http://store.summitracing.com/partdetail.asp?part=5330
Jalaber's site has a great writeup under Handling and he gives the part numbers for the "Black greasable bushings"
J.A.'s
Old Oct 27, 2003 | 08:33 AM
data's Avatar
Senior Member
I'll give them a call. So I assume I would buy 1 1\4 for both the front and rear?
Old Oct 27, 2003 | 12:41 PM
ALBPM's Avatar
No, the 1.25" is for an ADCO bar.
The Toyota stock bars are 1.00" for the front and 3/4" for the rear.
Also, you may need to replace the hardware for the brackets.
4 bolts for the front sway bar brackets, M8x1.25x30mm Grade 8.8, zinc coated
4 nylock nuts size M8x1.25 Grade 8.8, zinc coated, for the front sway bar bracket bolts
4 large outside diameter flat washers, size M10, zinc coated, for the front sway bar brackets
8 large outside diameter flat washers, size M8, zinc coated, for the front sway bar brackets
4 bolts for the rear sway bar brackets, M8x1.25x20mm Grade 8.8
4 flat washers, size M8, zinc coated, for the rear sway bar brackets
8 high collar split lock washers, size M8, zinc coated, for the front and rear sway bar brackets
Old Oct 27, 2003 | 12:52 PM
jalaber's Avatar
Right, factory bars are 1" front and 3/4 rear. Factory front hardware is captive type so you will need the new bolts listed on my site. Rear bolts may be too short with ES so to be safe get the bolts specd on my site as well. Dont want the rear bolts falling out like they did to me.
Old Oct 27, 2003 | 01:09 PM
data's Avatar
Senior Member
I ordered the antisway kit from wheelers offroad.
http://www.wheelersoffroad.com/tundraswaykit.htm
I'll have to get something for the rear though. I guess I'll just go ahead and replace the hardware while I'm at it.
thanks for the help guys!
Old Oct 27, 2003 | 01:10 PM
Cebby's Avatar
I've had mine for about 2 months without installing them, how about you?
Old Oct 27, 2003 | 01:24 PM
keisur's Avatar
Re: Front & Rear Swaybar bushings
go to pepboys or autozone. they have the Energy Suspension ones. You'll have to drill out the washers and bore out the bushings a little to fit them on the oem endlinks. that's what I did and they work fine. As for the greaseable bushings, Mike at Xtreme hooked me up with those and also the steering rack bushings.
Old Oct 27, 2003 | 01:29 PM
jalaber's Avatar
Are they zerk fitted? Hopefully they are otherwise they will squeak like hell and you will have to drop the bars each time to re-grease.
Old Oct 27, 2003 | 01:56 PM
mtnfreak's Avatar
Also available at Rocky Mountain Suspension.
Old Oct 27, 2003 | 04:47 PM
CTB's Avatar
CTB
Damn, you make me feel even worse...I've had mine since May! I hope to get motivated enough to put them on over Christmas.
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
deepmarsh
Aug 6, 2015 03:44 AM
toyoda8488
Jul 5, 2015 10:18 PM
