Front lower A-arm bushing orientation?
Old Nov 21, 2021 | 12:51 PM
floatingkiwi's Avatar
Hi All. Replacing some lower a arm bushings (the front ones) that have failed in a remarkably short time (toyo ones too).
I just wanted to check the orientation. There are rubber webs that connect the inner and out part of the bush. I pressed the new ones in with these rubber webs vertical as the originals came out, but is this correct?
Old Nov 23, 2021 | 07:05 AM
83's Avatar
83
Remind me what an 'a arm' is. I keep thinking about it and can't come up with anything. I feel like it's going to be really obvious...but I don't know what it is!
Old Nov 23, 2021 | 07:42 AM
Malcolm99's Avatar
Yes that is the correct orientation for the front lower control arm bushings so it can carry the vehicle load without changing suspension geometry. 83, I believe you just changed yours not long ago.
Old Nov 23, 2021 | 09:24 AM
83's Avatar
83
I did indeed. So "a arm" is another name for control arms? Where's the "a" come from?
I used poly bushings and don't remember any webbing.
Old Nov 23, 2021 | 10:47 AM
Malcolm99's Avatar
If you look at the control arm it resembles an “A” shape, some more so than others depending on the vehicle, both descriptions are common and acceptable, we tend to use LCA/UCA in short form since our vehicles have upper and lower control arms, whereas “a-arm” is a shorter written description than control arm and interchangeable in the industry. On the OE bushing the web is positioned vertical, and the Whiteline bushings have no orientation in that regard.
Old Nov 23, 2021 | 12:00 PM
83's Avatar
83
Got it!
joestox
Jul 19, 2021 07:30 AM
ianD
Aug 24, 2017 08:19 PM
YoshiMan
Nov 5, 2016 04:08 PM
RatLabGuy
Jun 26, 2011 01:09 PM
silent57
15
Nov 29, 2010 06:27 AM
