Front locker/LSD suggestions
Old Jan 10, 2011 | 07:15 PM
  #41
naksukow's Avatar
Originally Posted by capthoward
According to the application guide, that part number 911A342 isn't for trucks with shift on the fly. My rig has the push button 4WD...is that what the app guide is referring to? If so it looks like 911A445 is the right part number....?
That part number was on my invoice in 2006, so I am not sure about the accuracy today. I would call the tech line if you had question about the correct application.
Old Jan 12, 2011 | 01:34 PM
  #42
FoneRunner's Avatar
Finally got a hold of a guy at Randy's ring and pinion who says the correct part number is the 911A342 for V6 models and 911A445 for 4 cylinder models. He mentioned you can run 342 either way, but you would need a bearing kit to modify the 4 cylinder diff. Eaton Performance has replaced the 342 part number though which might affect someone's searching. They now use part number 911A644 in place of 911A342. I hope this helps somebody out there!
EDIT: And I ordered mine...whoohoo!
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
Eggslinger
Jun 8, 2019 03:32 PM
coffey50
Jul 28, 2015 10:55 AM
scottyg486
Jul 19, 2015 05:34 PM
