freeing a rusted lock?
Old Apr 13, 2005 | 09:46 AM
lee's Avatar
lee
i have my hitch cover locked in using a hitch lock thing.
well it came with a plastic cover over the key-hole side that fell off due to the harsh winter. as such, it has now rusted so badly that i cant get the key in! ive tried scraping with a swiss army knife and i still cant get the key to turn.
is there a fluid or solution i can spray on/in there to kill the rust and free the lock up?
thanks!
Old Apr 13, 2005 | 10:41 AM
Steveh29's Avatar
I'd try soaking it in the usual stuff - PB Blaster or Liquid Wrench. Spray some in there, rap it a few times with a hammer, spray a little more. Do that for a couple of days and see if it comes loose. Otherwise you might have to drill out the lock or cut it off.
Old Apr 13, 2005 | 11:02 AM
AKTaco's Avatar
If you can get your hands on some Kroil, that has worked very well in the past for me on locks, rusted nuts/bolts, etc. Let it sit for a day or so. Good luck!
Old Apr 13, 2005 | 11:28 AM
lee's Avatar
lee
thanks, ill try some of these solutions... appreciated.
Old Apr 13, 2005 | 01:59 PM
89macrunner's Avatar
pb blaster or wd-40 should do it
or that alcohol in a can...that stuff is also fun to light on fire
Old Apr 13, 2005 | 05:08 PM
AznSky's Avatar
yep, happened to me last week, I sprayed pb blaster in and was able to hammer the key in (bad mistake) cuz I couldn't get the key out, ended up breaking the key trying to turn it and getting the end part stuck inside the lock. I'm just gonna cut it off
Old Apr 14, 2005 | 05:38 PM
CynicX's Avatar
spray in some WD-40 everyday for about a week or more then try it...its happened to me and letting wd-40 soak in it for a week or so made it like new almost, i still use it matter of fact...
Old Apr 15, 2005 | 10:59 AM
3.4v6's Avatar
when evything fails turn to the saw-zal
j/k
westonian18
May 1, 2020 06:38 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
pyramid
Jul 30, 2015 10:05 AM
Athansinis
Jul 27, 2015 08:38 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
