FIXED!! Stupid PLASTIC clutch pedal bushing
Old Oct 22, 2003 | 04:59 PM
CMD93's Avatar
if it's a tiny little squeek, it's the little plastic bushing going out...same with mine
Splizaat,
Was that in response to my reply? If so, then it does apply to 2nd gens.
Old Oct 22, 2003 | 05:09 PM
SpLiZaaT's Avatar
Originally posted by CMD93
Splizaat,
yes
Old Oct 23, 2003 | 09:27 AM
CMD93's Avatar
Do I follow the same procedure for 3rd gens for the 2nd generation?
Anyone have a part #
thanks
Old Oct 23, 2003 | 11:29 AM
00Runner's Avatar
Wow! Great find Unhappy! My clutch squeak comes and goes, but when it comes it's so loud and annoying. At least I got my 4Runner while they still had a clutch! I've been dreading the thought of having to do regular bushing changes. I'm definately going to give this fix a try.
Old Oct 23, 2003 | 04:26 PM
  #25
BajaTaco's Avatar
Originally posted by 3.4Runner
(all of the 5-speed Tacoma guys will love you).
I think I'm in love...
Seriously - I have one of those bushings sitting here waiting to go on my '98 Tacoma. I have over 100,000 miles on it and haven't replaced it yet, but it has been squeaking for a loooong time.
Thank you mister Unhappy
As far as I know, the assembly did get changed on the newer generation Tacomas, and the dealer fix is to replace the entire pedal assembly with one of the newer ones. Too much $$ for me. I like the True Value spring better!
Old Oct 24, 2003 | 06:34 AM
  #26
keisur's Avatar
hehe, when mine had been squealling for a long time I didn't know what it was until I found two pieces of broken plastic on the floorboard that seemed to fit together like a horseshoe. I guess if I vacuumed a little more often I might have never figured it out. haha. I think I'm heading to ACE in about ten minutes for the spring.
Old Oct 27, 2003 | 08:28 AM
  #27
00Runner's Avatar
DONE! Here's to you Unhappy
I did this fix this weekend and it worked great. It also went very quickly since you don't have to put that rediculous spring back in.
This is what I noticed. The concept of the original spring making the clutch easier to push in as you get closer to the floorboard is barely noticeable. The spring rate on the new spring is so low that any increase in resistance as the clutch gets closer to the floorboard in not noticeable. The result is that there is no descernable difference in the performance of the clutch other than the lack of certain annoying frequencies.
Also if you are considering using a brake pedal return spring rather than the #70 spring I would advise against it. You can see in the picture that Unhappy posted that the new spring passes through an opening in a bracket that supports the old spring. There is very little clearance between the bracket and the spring with this fix. The larger diameter of the brake spring would definately contact this bracket. Of course, if this is a once for all fix, then you could just cut off that part of the bracket. This would also make the 4Runner lighter and could result in an additional 40 HP.
Gas to get to ACE: $1.00
New spring: $3.00
Getting rid of stupid,
annoying clutch squeak: PRICELESS!
Old Nov 10, 2003 | 05:58 AM
  #28
Solo's Avatar
Toyota Man of the Year Goes To....
Unhappy 99!!!!
I cannot explain how awesome this fix is! Not only could my Toyota dealer not figure it out but the ease and cost at which this replacement procedure is had me doing cartwheels afterwards. Seriously, I've had this problem for over a year now (on and off).
Yesterday, I couldn't take the squeaking anymore and thought I'd give this fix a try.
After about an hour and a half....done! Mind you, I am no mechanic (never even taken off my lower panel on the drivers side before ). And I don't feel any noticeable difference in tension and feel
The one thing that I would really pay attention to is dislodging the original spring. It is really in there tight and will require a good deal of effort to remove....be very careful when removing it as it will pop out with a great deal of force. Use Unhappy99's method of wrapping a towel around the original spring while using a screwdriver (or some other device) to dislodge it -
For some reason, tt also took me a few minutes to find that little hole on the L bracket too
Here is a quick recap:
Store: The Great Ace Hardware
Part: Handi-Pack Extension Spring - Part #88103 (5 X7/16) w/ .047 wire diameter. There was no #70 spring
Price: $1.99
Time: About 2 1/2 hours total. Stepped in the garage at 3:03 pm....stepped back in the house at 5:43 pm (includes test drive). Anyone else could do this in less than an hour.
This has made my day, week and month! Unhappy99....thanks for putting this one out there. Truly amazing!!
Hans
97 4 Runner SR5 4x4 5 speed
Old Nov 11, 2003 | 08:30 PM
  #29
Unhappy99's Avatar
I'm feeling the love.
Slightly less unhappy.
Old Nov 12, 2003 | 09:01 AM
  #30
yunaderis's Avatar
you dont happen to have an estimate on overall length of that true value spring do you? we dont have TV out here so I will need to find a similar spring.
thanks
Old Nov 12, 2003 | 09:06 AM
  #31
Solo's Avatar
thanks
Yunaderis,
The spring I got from "The Great Ace" hardware store was 5 inches long (my earlier post states the exact p/n and specs). Also, I believe Unhappy99's instructions show a picture of the spring he used that was almost exactly the same length as the brake pedal spring. Hope this helps.
Old Nov 12, 2003 | 09:12 AM
  #32
yunaderis's Avatar
Originally posted by Solo
Yunaderis,
great solo
"Here is a quick recap:
Price: $1.99"
i totally missed it...thanks again...I am heading to my local ACe today and grabbing one.....thanks again for your help....
for my tacoma, i only have to remove the connector on the pedal and the clutch assembly itself. I didnt have to remove the lower panel, it must be different on 4runners. I have changed this bushing three times in 100k miles.. Damn crappy design
thanks again
Old Nov 12, 2003 | 09:20 AM
  #33
Solo's Avatar
great solo
thanks again
Not a problem ) ....you will definitely love this fix (I can't believe I put up with that squeking for so long)
Hans
Old Nov 12, 2003 | 10:37 AM
  #34
CMD93's Avatar
Does this procedure apply only to the 3rd generations? If not, and it works for 2nd gen. do I follow the same procedure and buy the same parts.
Old Nov 12, 2003 | 11:08 AM
  #35
Solo's Avatar
According to earlier posts in this thread...I believe it does?
Old Nov 14, 2003 | 10:06 AM
  #36
yunaderis's Avatar
unhappy, you rock..i just got done replacing that ˟˟˟˟ty bushing design with my 2 dollar spring....way better and so much more satisfying to know i wont have to change that ˟˟˟˟e anytime soon. The spring i got was a bit too long and soft for my tastes, so i just shortened up the long end and bent a new hoop, and presto, shifting satisfaction to the Nth degree..... By shortening the spring a bit, it made the return a bit firmer and quicker. Which all in all is much better suited for my tastes, as I have always thought the stock setup was a bit weak.
thanks again for the idea......
Old Nov 15, 2003 | 05:26 PM
  #37
Nolan's Avatar
squeaky clutch be gone!
Today I got around to changing the spring. It went very easy, 1 hour start to finish. I found it pretty easy to pry the spring off. I pried it from the side as show here and it was effortless:
When I looked at the bracket after the torsion spring was off the place where the bushing normally goes was VERY mangled. I really dont think I could have replaced the bushing even if I wanted to because the metal was so messed up.
Old Dec 15, 2003 | 11:41 PM
  #38
Mystickal's Avatar
Unhappy Can't find the correct spring!
I live in Ventura County, in Southern California. The nearest True Value Hardware store is about 25 miles away - not really a big deal. There are a couple Ace Hardware stores within 15 miles, and some assorted other hardware stores.
None of them, not a single one, has the correct spring. I gave the guy at one of the Ace Hardware stores the part number, he tells me he doesn't even know how to look it up(!) The other Ace is a little better, but they claim they don't carry the right ones.
The other hardware stores in the neighborhood don't have springs that are 5" long - the closest ones were 6" and 3-1/2".
Tonight, I drove up to the True Value, and went through their spring box - their numbers start at #100 (and it's a TINY spring - they have no #70 spring and say that if they did have one, it would be about the size of a spring on a retractable ink pen).
Acehardware.com has springs for sale, but none that match the part number (or specs) provided. TrueValue.com doesn't even have the springs, period.
Am I in the spring black hole of the US??? Nobody else has posted that they've had any difficulty at all finding a spring, but it seems to me that mountains are going to have to move before I can fix this annoying 'creak' everytime I push the clutch pedal in.
I know that I'm a first time poster - I've had my 4-runner for a very short time, so I haven't had the occasion to make any beneficial comments - basically, I feel that if you don't have any info on something, you keep your mouth shut and try to learn as much as you can. However, despite my n00b status, I was hoping that I might be able to convince someone to pick up a spring for me and send it to me. I can shoot the money back to you through paypal. Please e-mail or PM me.
Thanks,
~Bill
Old Dec 16, 2003 | 05:29 AM
  #39
yunaderis's Avatar
hey mystickal
when i did this i got a spring that was a bit different than the one posted, it was a bit too long. I think as long as you can get a spring thats long enough and has enough force to return the pedal all the way up, you will be fine. So dont worry about the right part number, just get one thats about 5 inches or so long, and just trim it to fit the 4runner and to fit your personal clutch stiffness.
My spring was too long at first, so i just cut down the long straight hooked side, and bent another hook into it , which was real easy. So, just get one that will fit there, or go to the dealer and get the brake pedal return spring that was mentioned earlier in this thread. if you decide to go the hardware store spring route, just remember to get one long enough and then you can tinker with the pedal feel by reducing the length
good luck
Old Dec 16, 2003 | 05:51 AM
  #40
Mystickal's Avatar
Did the spring you used look like the spring in Unhappy99's picture? IE a relatively short coil section and relatively long hooks? After the TrueValue fiasco (I call it a fiasco because driving 25 miles in So Cal during rush hour can't truly be called anything else - and I had called them before hand and they claimed they had a #70 - turns out they thought I wanted a #170) I had thought about getting a longer spring and then just turning the hooks on the end to make it approximately the correct size.
The only problem with that was all the springs I saw there had long coil sections (over 90% of the length) and very short hooks. I think I might be able to put it in a vice and unwind a coil on each end, but it'd never be straight.
~Bill
