fixed high idle now ac clutch wont engage
Old Jul 12, 2012 | 01:31 AM
vital22re's Avatar
totally a bro
well if you can't figure it out than just "bypass" the amplifier like I told you how.
Old Jul 12, 2012 | 11:44 AM
KenC's Avatar
@vital22re I have a black wire with blue stripe but no black with yellow,it does have a light green with black stripe but I'm afraid to put power to it cause I'm not sure if its the correct 1 and further complicate my issue
Old Jul 12, 2012 | 01:52 PM
vital22re's Avatar
totally a bro
the wire changes color to the light green with black at a connecter by the amp. Verify that you do get 12v when ac is turned on at the black with blue stripe first though.
Old Jul 12, 2012 | 01:55 PM
KenC's Avatar
K ill have to do that tomorrow,if amp is bad I found 1 for 191.new I called all the local yards with no luck
Old Jul 12, 2012 | 02:00 PM
  #25
vital22re's Avatar
totally a bro
you might be able to use one from a 4runner. Also contanct deathcougar, he works for a toyota lexus wrecking yard. Tell him Vital sent you.
Old Jul 12, 2012 | 02:02 PM
  #26
KenC's Avatar
Ill try that tomorrow if that works than ill contact him,it worked today for a little while then after I shut truck off if wouldn't come back on at idle
Old Jul 13, 2012 | 09:29 AM
  #27
KenC's Avatar
I have 2 light green with black stripe wires,the black with a blue stripe is a key on hot
Old Sep 12, 2012 | 04:29 PM
  #28
ryanbt's Avatar
Any update on this? I'm lurking from t4r.org an have the same issue. You can see it here: http://www.toyota-4runner.org/showthread.php?t=123652
Old May 28, 2016 | 07:30 AM
  #29
Jjinsc's Avatar
Reviving and old thread. No update on this one and every thread I can find in any forum goes through the same steps but never gets a resolve posted. I am having this same issue and don't know what else to try. Would love to know if there was a solution found on this one.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
