First start engine squeak
Old Nov 2, 2010 | 01:05 PM
xxxtreme22r's Avatar
Originally Posted by yotarob2005
I think they mean when the fan clutch locks up, the fan "turns on".
yup yup yup.
dhoule's Avatar
The fan is definitely spinning immediately at startup. It might be that the fan clutch squeaks at low rpm, but its definitely turning
Old Nov 2, 2010 | 01:08 PM
yotarob2005's Avatar
If you want to find out what is squeaking on your truck you are just going to have to start taking things apart. I am betting fan clutch also, but the belt needs to come off & you need check the resistance of your fan clutch & get a feel on your pulleys for a bad bearing.
Old Nov 2, 2010 | 01:25 PM
it's not a matter of if it's turning or not, it's a matter of is it turning at the same rpm as the motor. You can clearly hear the fan speed up after that noise goes away.
Old Nov 2, 2010 | 01:27 PM
  #25
TheDurk's Avatar
Try this, for giggles. If the fan clutch is not engaged, it can be stopped with a rolled up newspaper. Try and hold the fan at startup, carefully and in a way that will not hurt you and see if you have the chirp with the blade not spinning. I think this will tell you a lot about what is going on, or at least rule out the clutch as part of the problem. It WILL engage shortly after startup, so be careful.
Aleeex_u
Jun 5, 2016 06:52 PM
camdenbuck
Jul 7, 2015 07:33 AM
Ladythump
Jul 4, 2015 03:35 PM
rbravo1
Jun 29, 2015 01:34 PM
gog1968
Jun 22, 2015 05:55 AM
