Finally Got some Fender Flares
Old Nov 18, 2004 | 04:39 PM
4RUNR's Avatar
Guest
Yes, they seem to be not as wide in the context of the first image.
Old Nov 18, 2004 | 04:52 PM
snwbrdpunk16's Avatar
Its probably just that angle, because they are pretty wide. That angle makes them look small. But seeing the bushwackers from that angle bushwackers are definately bigger.
Old Nov 18, 2004 | 05:03 PM
seafarinman's Avatar
I *used* to have a set of Bushwacker Extend-a-fender flares on the 94 but well after hitting them on rocks and trees, 3 of the 4 gave up the ghost, and I can't see spending all that $$$ again. I think that I will need to get some cut-out flares for the 87 though...
Old Nov 18, 2004 | 07:18 PM
DrumheadAR's Avatar
Looks like the front flares end higher to leave room for the running board end caps. Since you don't have boards, it just kinda leaves a big gap.
Old Nov 18, 2004 | 08:04 PM
  #25
Dont they make caps the cover that area after you take your running boards off??
Old Nov 18, 2004 | 09:04 PM
  #26
Govnor's Avatar
Yes they do make caps. I called a while back to check prices of some place in MI. The guy wanted to know if I had running boards or not to get the correct flare parts to go with them.
Old Nov 18, 2004 | 09:08 PM
  #27
I'm gonna have to look into caps for them! Thats the only thing i dont like about them, is how they stop so short.
Old Nov 18, 2004 | 09:49 PM
  #28
VandalRunner's Avatar
Cody,
Those are looking sweeeet! How do they attach underneath? Drilling holes or do they have some sort of other fastener.
Anthony
Old Nov 18, 2004 | 10:32 PM
  #29
No drilling required! The directions they came with are very limited and give just enough instruction to give u a littlest clue how to install them. I got pissed off on the rear ones and end up drilling little holes inside my fender. So if i take them off you wont even notice. But other than the rear quarter panel flare everything bolted on easy once u understood the directions.
Old Nov 19, 2004 | 03:59 AM
  #30
SLC Punk's Avatar
That looks a ton better!
Zach_trun
Jan 22, 2020 04:42 PM
94toyy
12
Sep 14, 2015 06:18 AM
gp66
Sep 7, 2015 08:29 AM
justdifferentials
Sep 5, 2015 06:52 PM
