A few transmission removal question...
Old Jun 29, 2003 | 06:18 PM
DH6twinotter's Avatar
Question A few transmission removal questions...
Hey all,
A friend of mine would like to rebuild the transmission on another friend of mine's 4Runner. His 4Runner is a '90, 4x4, auto, with the 3vz-e.
Now for the questions: The Haynes manual says to "remove the front driveaxles." Why do the drive axles need to be removed? Is there any way around this? Does the front diff need to be dropped to get to the transmission?
That's all the question I have.
Thanks for all the help.
Have fun all.
DH6twinotter
Old Jun 29, 2003 | 07:11 PM
Jay's Avatar
Jay
I typically left the front drive shaft attached to the transfer case, and removed it at the front diff. For the rear shaft, I disconnect it at the rear of the transmission and allow it to hang or just remove it all together.
Be careful that you dont allow the shaft to seperate at the "slip yoke" or if your gonna let it seperate that you mark the shaft so that the "phase" of the u-joints doesnt change or you will end up with a vibration.
Old Jun 29, 2003 | 08:19 PM
AgRunner06's Avatar
Post
Jay, check your PMs.
Old Jun 30, 2003 | 03:01 AM
Thanks, Jay. Can we leave the front driveaxles (cv alxes) and diff in place on the 4Runner while we remove the transmission?
Thanks again!
Have fun all.
DH6twinotter
Old Jun 30, 2003 | 03:17 AM
Jay's Avatar
Jay
Yes.
Quick list of things I can think of that require removal.
NEGATIVE BATTERY TERMINAL
1. Front Sway bar
2. Front Drive Shaft at Front Pinon Flange.
3. Rear Drive Shaft at Rear Transfer Case Flange.
4. Speedometer cable
5. Several Electrical Connectors and wiring fastened to trans housing
6. Fluid Lines (2)
7. Starter Mounting Bolts
8. Throttle Valve Control Cable (from throttle body to trans)
9. Torque Convertor to Flywheel bolts (6?)
10. Exhaust securing bracket
11. Bellhousing Bolts (6?)
12. Crossmember bolts (8)
With the vehicle on a hoist, I always left the crossmember attached to the transmission and just lowered the hole heaping thing down with a trans jack.
If I was to do it on the ground, perhaps Id use crossmember as a means to stablize the assembly from the sides of the vehicle.
Old Jun 30, 2003 | 03:05 PM
Wow! Thanks again Jay. You've been a lot of help. It's a relief that we don't have to remove the front axles and diff.
Thanks a lot!
Have fun all.
DH6twinotter
chuckross1957
Jun 28, 2019 10:19 PM
Dieselmann
Feb 19, 2019 02:57 AM
Tigbucket
Jul 30, 2015 07:29 PM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
