fan is ALWAYS ON !!
Old Sep 1, 2003 | 07:12 PM
mtnkid85's Avatar
fan is ALWAYS ON !!
Ive got a 85runner and the fan is always running , so I need to replace the fan clutch but dont know much about them and have never none this before so I would like to gain a little knowledge from any one who has done it before , or has some knowledge about this kind of stuff thanx alot !
Old Sep 1, 2003 | 07:23 PM
Gadget's Avatar
Well, it should always be turning, but not necessaraly locked up.
Turn the engine off and turn the fan by hand. You should be able to move it with a little bit of drag.
Then let the engine idle for a while. At some time the fan clutch should lock up and the fan should turn faster and if you rev the engine when this happend you should notice it moving a ton more air then when it is not locked up.
Gadget
www.GadgetOnline.com
Old Sep 1, 2003 | 07:42 PM
Plays_with_Toys's Avatar
Another alternative, if you indeed have a bad fan clutch, is to install a taurus fan. Do a search for "taurus fan install" Its a $30-60 flex-a-lite like mod, just takes some junkyard scrounging and wiring.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Aaron Logan
Sep 3, 2015 08:08 AM
