Factory Fog switch? (3rd Gen)
Old Sep 6, 2005 | 12:27 PM
BikKat's Avatar
I have the Hella factory fog lights that I installed, per the instructions from Toyota.
I got this crazy idea to replace the factory switch (no light) with a lighted switch so I got one of these (The illuminated switch, part number 00550-35976) and went to install it. I found only two wires connected to the old switch and the new switch requires three. I found that the new switch on http://www.4x4wire.com/toyota/4Runner/tech/switch/ is top-ground, middle-hot and bottom-from relay.
Tested the two wires I have black-red and black-green and found the black-red to be the hot. I added a ground wire to the top and it works, but no light on the switch. I tried every combo on the switch and could only get the crazy thing to light once and I have no idea what combo I had, but it was wrong as the fog lights were always lit.
I went to check the schematics on http://www.top4runners.com/ja/electrical.html#fogmod but found the link for the schematic is bad :-(
Anyone done this with un-modified factory fog lights?
SLG
Old Sep 8, 2005 | 05:57 AM
BikKat's Avatar
Anyone . . . Anyone . . . the war of 1812 . . . anyone?
Old Sep 8, 2005 | 06:09 AM
aowRS's Avatar
Corey will know - shoot him an email.
Andreas
Old Sep 8, 2005 | 09:56 AM
MTL_4runner's Avatar
If you have this 3 prong switch, you'll need both power and ground to make it light. I am not sure if the fogs on the 4runner are ground switched or positive switched (can't remember but I believe it is switched ground). If it is, then you need to run a positive to the 3rd post (2 prongs are the actual switch, the 3rd is for illumination) to get the switch to illuminate (if it is switched positive, then just run a ground to the other post).
Old Sep 8, 2005 | 10:00 AM
Bob_98SR5's Avatar
http://www.4runners.org/articles/hella500 hopefully that will help
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
93toyoguy
Aug 2, 2015 07:41 PM
jjrbus
Jul 27, 2015 11:06 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
