extremly bad gas milage
Old Dec 10, 2004 | 04:12 PM
dog.wagon's Avatar
Looking for some suggestions. I have a 2000 4runner with 400,000km, I used to get 450/km to a tank, in the last few weeks i know get 250/km to a tank. I have a KN air filter which is clean. Fuel filter hasn't been chagned in a while so that is my next step. Just looking for any other simple causes. My compression was not the greatest about a yr ago possible that a cylinder has gone. (sorry about the km thing us canadians you know0
Old Dec 10, 2004 | 04:32 PM
I'd think you'd know if a cylinder wasn't working properly...
Is your fan running all the time? I know it sounds odd, but mine is and I've noticed a *considerable* drop in mileage. Enough to where replacing w/ electric fan will pay for itself in a few months.
Old Dec 10, 2004 | 04:55 PM
leebee's Avatar
hey dog!
400,000 kms in 4yrs!? where do you drive? thats over 8,000 kms/month! better yet, when do you sleep?!
lee
Old Dec 10, 2004 | 05:27 PM
evilcow's Avatar
The metric system is the tool of the devil
Old Dec 11, 2004 | 05:38 AM
gwhayduke's Avatar
Nope. One of the few sensible things the French ever invented. And they probably did it while imbibing on some vino. Com'on....1 meter = 1/10,000,000 of the distance from the equator to the North Pole? It had to be a drunk Frenchman to dream that up.
But on the mileage....
Just got my own '99 and it's mileage isn't very good either. So here's my to do list....
1. Clean the MAF. The excess oil from K&N filters (and other brands too) coats the wires in the MAF, attracts dirt and gives faulty readings. Toss the K&N while you're at it and go back to the paper element or at least a foam-type element. K&N breathe better than stock, but test after test show they let in more fine dirt. I tossed mine on my '95 after noticing that I could see pinholes of daylight. Previous owner of my '99 used a K&N, so my MAF gets cleaned today.
2. Change your plugs. Folks here like NGK & Densos, but I've done over 100K between changes on Bosch Platinum +4's on the '95. Still haven't decided what I'm going to put in the '99 today.
3. Change the fuel filter. Toyota says it's a lifetime filter. Take it from a guy that's changed the FF a couple times. It ain't. When you change it, it will leak the brownest crap out one end.
4. Swap in some dino oil into the crankcase and AutoRX your engine. Do the whole treatment, then swap in a good, synthetic oil (Castrol Syntec does not qualify). The AutoRX cleans out a lot of the crap out of your engine so it can run the way it ought to. The synthetic really makes a difference (about 1mpg) in how your engine runs. I've used nothing but in all my cars since an '89 Corolla.
5. Swap out the tranny, transfer case, front & rear diff oil with a good synthetic. It gained me about 1 mpg on the '95.
6. Go to your Magnaflow muffler dealer and order the longest one they make and get it installed. It'll have a low, quiet rumble, slightly louder than stock, and let the engine breathe as efficiently as possible with stock manifolds.
7. Make sure your tires are running at least at the recommended pressures, maybe a bit more (I go as high as an un-scientific 32 PSI...Not sure whether you use Pascals, Atm's, or KGM's or I'd do the conversion for you)
All of this should cost less than about $200 (American). I think that's about $25,000 pesos or about $63,000 CDN.
After that, check your mileage a couple tanks and repost.
Old Dec 11, 2004 | 06:17 AM
X-AWDriver's Avatar
My '99 has been only getting 14mpg (only had it about 6 weeks) and I'm cleaning the MAF today and am using a brand new OEM air filter so I'll post my results as soon as I burn through this tank.
Old Dec 11, 2004 | 06:21 AM
rimpainter.com's Avatar
I would really focus on that compression "problem" first. Give us the full cylinder report. How far is it out of specified range?
Old Dec 11, 2004 | 11:27 AM
leebee's Avatar
hey hayduke!
i know the us greenback has been climbing in value lately but i didnt think it went that high!
lee
Old Dec 11, 2004 | 12:33 PM
boyzWidToyz's Avatar
i'd be willing to bet your cat is toast
Old Dec 11, 2004 | 03:07 PM
gwhayduke's Avatar
Originally Posted by leebee
hey hayduke!
lee
Au contraire Cannuck (not meant to be derrogatory) I think it fell some more after the election.
Ssshhh!....Hear that?
Doggone Homeland Security is monitoring my transmissions again.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
pyramid
Jul 30, 2015 10:05 AM
harrisdawg
Jul 26, 2015 09:42 AM
