extending my drive line in my 96 taco
Old Mar 9, 2012 | 07:51 PM
96taco_yo's Avatar
i just got a 6 inch lift for my 96 taco and need to extend my driveline, is this something i can do at home or is something i have to bring to a shop, i got a welder and the works in my shop and was wondering if i could save myself sum money and do it myself????
Old Mar 9, 2012 | 08:35 PM
ThatGuy1295's Avatar
I don't know.. can you?
Old Mar 9, 2012 | 08:39 PM
But seriously. You can extend it if your real carefull about making it straight. But then you need to have it balanced. If your even remotely unsure then id just have a drivline shop do it. Most people will do their front drivelines them selves because its a low speed thing that doesn't require balancing. But the rear needs to be tities.
And you need the magic tube. If you do it yourself, make sure you get the magic tube.
Old Mar 9, 2012 | 08:40 PM
4Crawler's Avatar
You generally need to pick up the proper size tube as much longer as you need and cut out the existing tube and weld in the new section. Then get it straightened and balanced to make it run smooth.
Another option for up to 1.5" longer is a drive shaft spacer:
- http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
Old Mar 10, 2012 | 05:55 AM
aowRS's Avatar
Another option for up to 1.5" longer is a drive shaft spacer.
Very clean solution!
Andreas
Old Mar 11, 2012 | 09:09 AM
96taco_yo's Avatar
can sum1 shoot me in a direction i could check out the materials involved to do this myself
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
TokyoD23
Jul 12, 2015 06:01 AM
87turboPA
Jul 9, 2015 05:58 AM
