Expired warranty problem? please read
Old Feb 21, 2004 | 04:05 PM
scubasteve83's Avatar
Banned for dupe accounts
Ok I bought my 4runner used last August and they gave my the basic 3 month or 3,000 mile warranty. They fixed some things for me before I got it. The A/C wasnt cold so the rifilled it BUT I specifically asked them to check for leaks in the sysem and they said that they did and it was fine. Well one month later I drivin my 3000 miles and the warranty was up the A/C stopped being cold again. But it was starting to get cold so I put it off but now with summer coming up I will need A/C. Do you think if I go in to the dealership and say "you guys told me there was no leak and obviously there is." will they fix it. Also if they say no should I e-mail Toyota and bitch till it gets fixed? Whats their E-mail address. Anybody let me know problems that you have had fixed any other situations like this! Thanks
Old Feb 21, 2004 | 04:44 PM
BUMP
Please help any advise at all woill be greatly appreciated
Old Feb 21, 2004 | 05:06 PM
gtaSR5's Avatar
How many miles are you over your warranty? If you have a good relationship with your dealership and approach them nicely, they might fix it for you. I know some dealerships will give you a hard time if it's 1 mile over your warranty.
From my understanding the a/c system is a closed system and if it needs to be re-charged, then there is a leak. I think they should fix it under warranty and hopefully they won't give you too much trouble with it.
Old Feb 21, 2004 | 05:12 PM
Im probably about 7,000 over warranty but if was something that broke after I bought it then I wouldnt complain but they told me there was no problem and it stopped working after a month but I just put it off during winter. The guy who sold me the car was awsome and even said if I needed parts to let him buy them cause he gets a discount but he moved and I dont know anybody there now.
Old Feb 21, 2004 | 05:24 PM
Brendan's Avatar
Personally, I think you're SOL. It sounds like you should have went in when you first noticed the problem. If you're lucky, they might cut you in for 30% off. Good luck.
Old Feb 21, 2004 | 05:27 PM
Maybe they will at least find the problem and I can start my junkyard search for the fix.
Old Feb 22, 2004 | 06:08 AM
Paul H.'s Avatar
Since you already complained about the problem once and they said there wasn't one, then they should fix it. Complain to the service manager if the write up guy doesn't help you. And make sure you have the original write up for the problem.
Old Feb 22, 2004 | 06:22 AM
4Paws's Avatar
You might find it will be difficult for someone to work on your AC. R-12, the refrigerant inside, is not longer manufactured in the US and 1# of it may run as high as $40 in places. Converting the system to 134A after fixing the leaks may be a better alternatine. It may require changing compressors and other parts.
Old Feb 22, 2004 | 07:22 AM
Yoda's Avatar
$40 a lb would be a bargain! Last I heard it was about $80 in the Seattle area. If it has to be repaired, do try to convert to the new freon (R134A)
Old Feb 22, 2004 | 01:58 PM
What year did they change and does anyone think it would be possible to pull the parts out of a newer 4runner and put them in mine?
Road Bull
Oct 10, 2015 04:55 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Coreyr384
Jul 10, 2015 11:13 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
