Exhaust Gaskets (what a slut!)
Old May 25, 2005 | 07:38 PM
Mystickal's Avatar
Originally Posted by farmerj
I will run my torques at the high end or add a couple of pounds to it to make up for the lubricating properties of it.
It is my understanding that you use anti-seize in just about every case where you have to apply precise torque; that way the stud is lubricated and the pressure/torque is applied uniformly and evenly. I always use anti-seize whenever I am torquing something down, whether it is a spark plug or a lug nut, and I use whatever the specified value is. Going to high can cause problems (such as spark plug going in to far and not getting optimum combustion, warping rotors, etc).
~Bill
Old May 26, 2005 | 08:39 AM
Ironmike4x4's Avatar
Just going from what was given to us from instructors in high school and 3 years of tech school for automotive. Guess I never guestioned them because I found it to work for the purpose.
I meant it coming with the O2 sensors.
Old May 26, 2005 | 11:01 AM
NorCalVP's Avatar
I had the same problem with my 96, When i was replacing the clutch every nut and bolt came out perfectly, except that damn last exhause collector nut. It started to get tight, so i stopped and lubed it up good, then snap!. I tried heat, I tried PB blaster, Vise Grips, I even tried welding a nut to it twice... it still just sat there laughing at me... I finally drilled it out, and used a Helicoil to put in the new stud... I almost with the a nut and bolt, but like the stock look better, so i spent a whole day just getting the helicoil in.
The stud that broke was the one closest to the frame rail, so there isn't any room for a drill, I had to get a 90 degree drill to do it...
But all is done, and i'm happy that I now have a new clutch, and my exhaust looks stock.
Old May 26, 2005 | 12:42 PM
Pinion's Avatar
Have you guys tried loosening all of the nuts first instead of taking them off one at a time? I have found that for a lot of things, the last nut tends to get more load on it than the rest and that by just loosening them all a little at first really helps.
PBlaster definitely kicks ass.
Old May 26, 2005 | 02:03 PM
  #25
Agent 7's Avatar
In my case all the nuts were loosend to begin with... so this really didn't have anything to do with that, unfortunately.....
Old May 26, 2005 | 02:04 PM
  #26
Agent 7's Avatar
Mine was the one closest to the motor...
tj884Rdlx
Aug 28, 2015 12:04 PM
ethanethan
Engine Swaps
Aug 11, 2015 09:09 AM
accuracy
Aug 6, 2015 12:32 PM
Dakotaneu
Jul 27, 2015 12:03 AM
Coreyr384
Jul 10, 2015 11:13 AM
