eq. / amp question
Old Feb 18, 2003 | 02:47 PM
C2damuthafuqinLO's Avatar
eq. / amp question
So i got a digital equalizer..and i need an external amp for both the front and rear speakers.... does anyone know how much wattage i need for these amps? Maybe a general guess? I assume it depends on how much my speakers can handle....but i dunno the answer to that... i have 6.5'' rockford's in the front...5 1/4'' pioneer speakers in the rear... and that's all i know..
Also.. where's the ideal place for these amps to be installed..from a conveniance standpoint?
Old Feb 18, 2003 | 02:54 PM
trd90toyota's Avatar
If the amps is small, you can put it under the seat or if you want, you can place it on on the back of the rear seats. It will look real clean if you can do it on the back of the seats.
Old Feb 18, 2003 | 03:28 PM
White SR5's Avatar
To choose the right amp you really need to know the specifics of your speakers. Some 5.25's are 30 watts, others can be 300 watts. Amps can be under a seat or mounted t the back seat, or on the roof if you really want it... I guess i you really want a roug estimate, your amp probablyneeds o be between 150 and 300 amps, if I'm guessing at your speakers with any luck.
Zach
Old Feb 18, 2003 | 06:17 PM
I did some digging...
Front speakers: 2-50 watt recommended...peaks @ 100
Back speakers: 2-35 watt recommended...peaks @ 150
So do i go w/ like...75 watts... and 50 watts? Or...do i go with the peak ??
Old Feb 18, 2003 | 06:22 PM
Bumpin' Yota's Avatar
Peak wattage means nothing go by rms for everything.
I'd highly suggest you get a single 4 channel amp rated for ~75watts x 4 @ 4ohms.
Steve
80Truck
Oct 12, 2025 07:25 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
