Engine Ticking....
Old Jun 3, 2004 | 09:16 AM
mxracer0486's Avatar
Engine Ticking....
OK I think I have posted this before but no replies....
Whenever its warm out, theres a ticking from my engine compartment. The last 2 weeks it has been around 70-85 degrees here and there was no ticking. But then the last 2 days its been over 90 degrees and the ticking is back.
Its not a rythmic ticking, its like a, well its hard to explain its just a loud ticking, you hear it most at idle or LOW RPMS.
Just wondering if you guys have any ideas.....
Old Jun 3, 2004 | 11:39 AM
radrex's Avatar
Injectors (Normal) - or Valve Clearance (Also probably Normal) - or Both. Piston Slap - does it have a butt load of miles on it??
Ticking is different from Knocking. Knocking is bad.
Old Jun 3, 2004 | 11:58 AM
Fink's Avatar
Ticking is normal for the 3.0...its just a noisy engine. You could get a valve adjustment done but I'm not sure it'd be worth it.
He asked a good question, how many miles are on it? If there are a lot then it could be piston slap (bad)...but I would imagine its just the regular old ticking that all 3.0's do.
Fink
Old Jun 3, 2004 | 12:17 PM
Maddog's Avatar
Thinking outside the square,check all your spark plug leads ,on my be damaged or melted & could be arching somwhere.but you will also notice the engine miss slightly when this happens.
just a thought.
Old Jun 3, 2004 | 12:49 PM
The Runner has 224K miles on it, the guy I bought it from said it has 120K after the rebuild...
I don't think its a normal noise because its no rythmic, meaning it doesn't happen on a tap tap tap basis, its like tap second tap second second second tap second second tap secondsecondsecondsecond tap with the "second" being like a second.
And it only happens when it gets hot outside, doesn't happen below 85 Degrees outside.
does that help you guys a litle bit better?
Old Jun 3, 2004 | 02:47 PM
radrex's Avatar
224k -- jeezus - if it still runs good and doesn't miss or burn oil, I'd definetly start pulling plug wires - one at a time and see if the tick goes away - then concentrate on the cylinder that is tapping. definetely look at the wires for shorting.
Old Jun 3, 2004 | 02:51 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
My 3.slow did the same thing in extreme heat. Usually all I had to do was top-off the oil to the full mark. Also, topping it off or putting in the next higher viscosity may help.
Old Jun 3, 2004 | 03:00 PM
HAHA Thats not even that much, my 1985 4Runner had 354K Miles on it. I wish I never got rid of that.
Thanx for the info, Ill try adding some oil and stuff to it see if that help. It doesn't burn oil, as in i don't see any smoke, it does leak from the rear main seal. I checked in the dark for arking of the plug wires but couldn't find anything because it wasn't hot enough to make the noise...
Old Jun 3, 2004 | 05:37 PM
My99's Avatar
THe 90 I have ticks all the time. But nothing unlike my brother's 95 did with 50K on it back in the day. Something about the 3.0's just make a ticking noise that you can hear inside the cabin all the time.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
