Engine swap
Old Jan 18, 2021 | 03:39 AM
Connie4runner's Avatar
Engine swap
So I just cracked the heads on my 97 4runner. It is the sr5 with a 3.4 l motor. I have a 4 runner with a 3.0 that is not blown. Can I swap out the 3.4 with the 3.0?
Old Jan 18, 2021 | 05:15 AM
fierohink's Avatar
The 3VZ and 5VZ heads are different. They have different passageways for cooling.
Old Jan 18, 2021 | 07:35 AM
Malcolm99's Avatar
Is it a 3vz-E, I think you will find a lot of incompatibilities like sensors, wires, cluster, Obd2 and ECU making it a lot harder than finding another 5vz-Fe that will drop right back in. You would have to have driven it without rad fluid to blow both heads usually, and at that point it would be wise to try another motor incase other damage has occurred.
4rnner9085
Sep 15, 2014 01:42 PM
firsttruck1985
Oct 16, 2009 07:52 AM
mike513
Dec 12, 2005 09:29 PM
boo204
Feb 24, 2004 01:31 PM
