engine noise
Old Jan 16, 2004 | 10:28 PM
MY024runner's Avatar
engine noise
I have a 2002 4runner and its has 36,000 miles almost. Also its up to date with service at the dealer. Does anyone know about a clicking sound in the engine when it is started also sometimes in reverse. It sounds more like a clicking gas stove not really like the pinging valve noise if you guys know what I mean. Any thoughts appreciated thanks in advance
Old Jan 16, 2004 | 10:51 PM
Mike06's Avatar
I would just take it to the dealer, it should be covered under warranty.
Old Jan 18, 2004 | 09:50 AM
I am actually on 41,000 and warrenty is gone now anyone else have any answers pls. Thanks in advance
Old Jan 18, 2004 | 10:42 AM
Mike Murrell's Avatar
If you took it to a Toyota dealer for service, there's a good chance that little if anything was ever done to it.
You might have a bad lifter. What's the oil level look like?
I'd change the oil and filter - do it yourself so you know it really gets done. Don't use heavy oils like 10W/40, 20W/50. I wouldn't go heavier than 5W/30 in your motor.
Drive it for a 100 miles or so, then add a can of engine flush. Follow directions on can of flush. You'll drain the oil and change filter again. You may need to do this a few times.
If the vehicle was dealer-maintained, you're oil likely wasn't changed. They put a number on it, park it in a corner, let it collect dust during the day, then hand it back to you at 5pm with a $30 bill. This goes on all of the time.
Old Jan 18, 2004 | 10:47 AM
MTL_4runner's Avatar
The lifters are solid on a 2002 not hydraulic.
Couple of things:
1) could be an exhaust leak
2) could be a valve needs shimming
3) the evap canister has been known to tick too (there is a recall for that)
4) could be an arcing of a wire (not likely tho)
Old Jan 18, 2004 | 05:56 PM
Thanks for the replies. I always check my 4runner after I leave the dealer. The oil is clean and on the middle mark not too low or high.Thanks anymore suggestions are appreciated
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
Gamble_STi
Jul 7, 2015 07:54 PM
