Engine Misfire.. Please Help
Old Mar 2, 2010 | 01:25 AM
  #41
1990yota-pickup's Avatar
good for lubing your main rod aswell
Old Mar 2, 2010 | 05:14 AM
  #42
eddieleephd's Avatar
do not forget to check your timing marks on crank and the cams bring to TDC and double check
https://www.yotatech.com/forums/f2/r.../#post51380235
dgl4runner
Ok so i started this thread a year ago and just now fixed the problem this past weekend. I finally gave in took it to a shop to get a diagnostic, ran me bout $70. After all the stores (autozone, oreilly, napa) and everyone swearing it wasnt a timing issue were wrong! The shop said it needed new water pump timign belt and serpentine belts. I replaced all this and it runs beautifully. so if you havent changed your timing belt in a while you wmight want to check on that mine was worn out. good luck with figuring out whats wrong.
good for lubing your main rod as well "huh huh huh he said lube your main rod" enough Bevis
Old Mar 2, 2010 | 09:05 AM
  #43
kawicowboy's Avatar
Thanks guys, You know I looked right at that and thought it was silicon.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
