Engine Lean with aftermarket exhaust
Old Mar 20, 2007 | 07:55 AM
aquasport17's Avatar
Ok, I was able to see from the state inspection in 2005 that the code was a P0420. That mean anything to anyone?
Old Mar 20, 2007 | 07:58 AM
MTL_4runner's Avatar
Ok that's not a good one.
Just do a search and you'll find lots of info on that code.
Old Mar 20, 2007 | 08:11 AM
bwhyit's Avatar
P0420 is for catalyst efficiency. Most likely culprit is a bad Cat.
Old Mar 20, 2007 | 08:34 AM
Okay - can i start by testing or replacing the sensors? Do you recommend any CATs that would perform stock as far as the computer is concerned?
Old Mar 20, 2007 | 08:35 AM
  #25
Yep, not a cheap fix on 4runners with dual cats.
There are some ways around it though.
Ok on your 2000 4runner is it a cali spec truck? in other words, does it have dual cats?
Old Mar 20, 2007 | 08:40 AM
  #26
00 year. I did see there is a device to get around the issues. I'd rather do it right and replace whats wrong. It's possible that with the engine running lean for many years, I burned out the CAT. Can I test the sensor to make sure? the stock sensor is about 130 bucks from toyota - but I get the feeling the sensor is probably not the culprit.
Old Mar 20, 2007 | 08:42 AM
  #27
I found this in one of the foums .....
measure the voltage at the oxygen sensor on Bank 1 (the rear sensor, or the sensor after the converter). The voltage should be low and steady (~200mV, depends on the vehicle). If the voltage varies (e.g. 100mV to 600mV) then it's time to replace the catalytic converter. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
Old Mar 20, 2007 | 09:09 AM
  #28
The issue for you is that most of the O2 (A/F) sensor and cat testing is going to require a graphing OBD reader (either laptop PC or Palm based). If you have a Palm PDA or laptop PC then you might consider getting an Auterra or BR-3 reader to help you with this issue. Otherwise, you'll potentially be doing alot of expensive parts replacement for no good reason (it could be the front A/F sensor, rear O2 sensor or the cats that are actually causing the code.....also potentially an exhaust leak). You could also bring it into the dealer and have them verify the cat or sensor(s) as being bad, but those trips are never cheap.
Ironically the Auterra review here tackles the exact same code (but don't assume your truck will have the same fix):
http://www.troublecodes.net/articles...r_Review.shtml
Old Mar 20, 2007 | 09:20 AM
  #29
I'm going to buy that today. Not messing around. I have a VAG COM for my VW diesels and it has paid for itself.
I have an IBM laptop with USB (no serial). What components would you recommend? I'm looking at the website for the tool now. Do I need the CAN version or just the one for 189?
Old Mar 20, 2007 | 09:34 AM
  #30
No, you don't need CAN. Toyota didn't put CAN in 4runners until 2005. Also check eBay because the company sells on there too (usually a bit cheaper). That's where I picked up my Auterra back in 2001. If you have a laptop then you might also look at the BR-3 as well because it's even cheaper and does almost the same thing (Auterra has a few more features, but both have code reading and full graphing capability). I personally like the Auterra setup better and use mine alot so I'd probably opt to pay a bit extra, but that's just IMHO.
Here's the website for the BR-3 reader:
http://obddiagnostics.com/
Here's someone selling the entire Auterra CAN setup with PDA! (A-300 supports all OBD protocols and it's very portable)
http://cgi.ebay.com/ebaymotors/A-300...spagenameZWDVW
.......ok, if I could get it for $250, that one on eBay is very tempting for me too.
Old Mar 20, 2007 | 09:45 AM
  #31
Well, I don't have a serial port. I do have a USB to Serial adapter which may work, or I'll have to buy the CAN USB one. DOes the BR-3 use USB? Can you provide a link- I didn't see much when I googled it.
Old Mar 20, 2007 | 09:49 AM
  #32
Never Mind. I found it - No USB on that either. Does say it will work with the adapter though.
Old Mar 20, 2007 | 10:04 AM
  #33
Those USB to serial adapters always make me nervous (esp if your running Win XP). I've tried a few myself and didn't find one that worked well (not that there aren't any out there that might work). Most of them seemed to be compatable with everything up to Win Millenium or Win 2000 and then support was non-existent after that.
Old Mar 20, 2007 | 10:09 AM
  #34
Yeah - I'm going to get the USB one with CAN. Ebay for 199. Then Ii will have native USB.
Old Mar 20, 2007 | 10:14 AM
  #35
That is the smart thing to do.
Old Mar 20, 2007 | 10:15 AM
  #36
It's on it's way
Old Mar 20, 2007 | 10:16 AM
  #37
Thanks for all your help. I may need some help diagnosing the issue further - I will read the thread you posted on it above. What type of reading should i expect from a working 02 sensor?
Old Mar 20, 2007 | 10:31 AM
  #38
There was a thread a short while back where I helped someone else that was diagnosing an issue with the Auterra on a laptop (there were screenshots and everything!), but I can't find it since the serach function on YT is pretty much toast now for stuff like that. If I get more time, I'll see if I can dig it up for you.
.....finally found it:
https://www.yotatech.com/forums/f2/rough-idle-vibration-108063/
Old Mar 20, 2007 | 11:38 AM
  #39
Thanks- I'll post the details when I get the device. I'm still not sure what is normal voltage readings for the sensors and what is abnormal. But I'll figure that out when i get the unit.
J
Old Mar 29, 2007 | 02:31 PM
  #40
I played with the tool a bit - it doesn't look like I can get the 02 sensor test to work like you posted in your link above. Does my 4runner support that? I took some screen shots and I will post them here.
