EGR valve
Old Dec 1, 2004 | 03:23 PM
desert whomper's Avatar
EGR valve
is ti any benifit to take out the egr valve and plug it on both sides so u only get clean air coming into the intake plenum?
Old Dec 1, 2004 | 03:39 PM
kyle_22r's Avatar
not much, especially with a 22RE. keeping it will lower your chances of pinging because your combustion chamber temp will be cooler
Old Dec 2, 2004 | 02:10 AM
epic37311's Avatar
hmmmm...........
Old Dec 2, 2004 | 03:12 AM
HondaTec521's Avatar
NO benifit,except pinging and higher NOx readings.
Old Dec 2, 2004 | 03:26 AM
mikedog's Avatar
Like Kyle said.
The EGR helps to reduce combustion temps. Getting rid of it on your 22RE will make it run worse not better. You will have light throttle hesitation, mid RPM bog, pinging under load and poor fuel economy.
Remember, the ECU will retard the timing via knock sensor without the EGR so you will be slower not faster without it. Also, if you have emissions testing in your area, you'll probably fail the NOx part of the test.
idadan208
Sep 7, 2015 09:06 AM
Scatterbrain
Sep 3, 2015 06:46 PM
montanatruck
Jul 25, 2015 03:45 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
