ECM repair
Old Dec 9, 2017 | 06:02 PM
BLRobertson's Avatar
ECM repair
Does anybody have a suggestion on where to send an ECM for repair? Also is it possible to disable the immobilizer function? Thanks
Old Dec 9, 2017 | 07:20 PM
fierohink's Avatar
What is your ECM doing or not doing? Maybe check with some of the eBay vendors that repair ETACs. Sometimes a fried circuit is toast and that’s that.
Also what rig do you have? Someone may have a spare to sell
Old Dec 10, 2017 | 01:24 AM
wyoming9's Avatar
Red face
I sent one off to ECM depot in Texas .
Been some Time I think I paid $300.00 exchange it comes with a life time warranty unless it gets wet .
Water or a Major Voltage spike about the only thing that kills them
Old Dec 10, 2017 | 04:18 AM
An early 99 4Runner was the donor vehicle for a 3.4 auto swap into my 94 pickup. It's ran great for 2 yrs but lately it's hit or miss as to whether it's going to start.
When I put my backup ECM in it fires up but that ecm is from a 00 4Runner and the engine runs fine I just get a couple transmission codes. I was looking for recommendations on who had good luck or bad with all the different repair facilities. Thanks wyoming9, I'll look into those guys.
Old Dec 10, 2017 | 05:38 AM
Malcolm99's Avatar
I'm not sure if this is related or completely true, but I read that the 99' ECU with immobilizer must have a programmed chipped key close by to work, I also read that if you lose ALL your keys, specifically on a early 99' the ECU wasn't designed to be reprogrammed and 1 must by a new ECU with a programmed key, supposedly this was corrected in 2000+ so that if you lost ALL your keys the ECU could still be programmed to except a new key. Did you tape the donor key to the replacement 99' immobilizer ECU, strange it would start at all without the programmed key close by..
Old Dec 10, 2017 | 11:42 AM
Malcolm99- yes I've been running with the key and transponder amplifier up under the kick panel with the ecm. . But you're thinking the ecm for the limited with engine immobilizer can't be reprogrammed. So going to an ECM from a SR5 without the immobilizer would be the way I need to go.
Old Dec 10, 2017 | 08:13 PM
fierohink's Avatar
Let me check my garage tomorrow. I have an ECM for a ‘97 LTD Auto 3.4. I just need to find it. It’s yours to try if you pay shipping.
Old Dec 11, 2017 | 06:08 AM
fierohink's Avatar
Found it.
Old Dec 11, 2017 | 05:24 PM
fierohink- really appreciate the offer but it looks like the connectors are different. My ecm is a 89661-3D570.
Old Feb 13, 2018 | 09:27 PM
BN-2B's Avatar
...About that Brain...
Greetings fierohink, wondering if that ECM is still available.
Old Feb 18, 2018 | 11:04 AM
fierohink's Avatar
Absolutely!!
PM me your address and I'll get a price to ship it.
BLRobertson
3.4 Swaps
Dec 9, 2017 06:41 AM
toyospearo
Jul 11, 2010 09:27 PM
Michigan Mud Farmer
Mar 7, 2008 05:19 PM
