e-locker wiring help needed
Old Aug 5, 2004 | 01:49 PM
rimpainter.com's Avatar
I understand this for the most part, but I have a couple questions:
1. The "RR diff lock" switch that I "stole" from my donor rig only has 2 wires coming out of the plug. Why does this diagram show 4?
2. The switch in the lower right corner of this diagram, can someone tell me what that is? Is it homemade?
http://home.off-road.com/~kemanuel/e...ker_wiring.jpg
Wiring sucks!
Thanks for the help.
Old Aug 5, 2004 | 05:52 PM
BruceTS's Avatar
http://www.tundrasolutions.com/photo...sort/1/cat/500
NOTE* I didn't create the image in the above link, but found it during one of my searches and forgot where I got it from.
Old Aug 5, 2004 | 06:02 PM
That rocks Bruce, thank you so much!
Old Aug 5, 2004 | 07:14 PM
Sorry, one last question:
When I go to Radio Shack and ask for a "diode" what exactly am I looking for? Any particular specifications?
Old Aug 5, 2004 | 07:54 PM
Localmotion's Avatar
im not completely sure but i believe most if not all diodes are the same. They are all semiconductors and are measured in miliamps, i think. I believe they are pretty standard. Hope this helps....and correct me if im wrong
Matt
Old Aug 6, 2004 | 04:12 AM
p1michaud's Avatar
Exclamation Wires and switches
Hi 96 Runner,
I'm not sure if you have your answer yet, but I'll tell you what I know (or think I do...).
1-The 2 extra wires on the RR Diff Lock switch are to illuminate the RR Diff switch itself. In the diagram it is wired to the dash lights so that the brightness can be controlled with the dim switch for the dash lights.
2-The switch in lower right hand corner is simply the factory limit switch (or position switch if you prefer) for you locker. It tells the ECU that you are locked or unlocked. If you look at the E-locker there is a 5 pin connector to the servo motor and a 2 pin connector for the limit swith. The difference between the Locked/Free/Ground switch in the same box as the diff lock motor in the diagram and this one is that the position switch is used to detecd if you are locked or not. The Locked/Free/Ground swith next to the motor is used to control power to the diff lock motor and turn it off when it is in position. Does that make any sense to you or did I just confuse everything?
I'm in the midst of making a control unit and wiring harness using a factory RR Diff Lock switch and ECU myself. I believe that I have managed to decipher what all the wires do.
Cheers!
Old Aug 6, 2004 | 05:05 AM
BruceTS's Avatar
Cheers!
I've already drawn up a schematic of the actual ECU and had planned on recreating a simplified version that bypassed the speed sensor and shifter lock out. Here's something that I posted elsewhere;
Originally Posted by BruceTS
Here's a breakdown on the mechanics of the E-Locker:
When you activate the RR switch it sends 12v, pin #4 Green/Yellow, to the Locker ECU. The ECU then checks to see if Pin #8 the Grey wire(Blue/Red on 4Runners) is grounded or in 4WL, then checks to see if the Speed sensor, pin #10 the green/orange is below 5MPH, at the same time it activates the flashing RR light pin #1 Yellow/Blue wire. If these conditions are met, then it does a check with a switch in the E-Locker at the axle pin #9 to make sure it's grounded (locker dis-engaged). If all these conditions are met it activate's Relay 1(inside the ECU) switching it from being grounded to supplying 12v to pin #3 the Light Green wire. At this point the E-Locker motor starts turning, moving a shift fork to lock the diff, if the teeth don't line up, the locker won't engage until there is some movement, which is why you turn slightly. Once the fork shifts fully over, the switch opens the circuit to pin #9 and grounds pin #6 the Light Green/Black wire and turns the power off the Relay 1 grounding pin #3, stopping the motor, as well as closing another switch the Yellow/Blue to turn the RR light solid, now the E-Locker if fully engaged.
When you turn off the switch, it goes through the same checks, but with a few differences, since pin #6 is now grounded and no power is at pin #4 the ECU activates Relay 2(inside the ECU) switching pin #2 Light Green/Red from ground to power, reversing the motor, unlocking the diff, again moving slowly in a slight turn the locker will help. Then pin #6 is opened and pin #9 is grounded, shutting off Relay 2 and the lock detection switch in the e-locker is opened turning off the RR light.
Pin #5 Black/White or Black/Yellow is the main power
Pin #7 Wihte/Black is ground
Another note* The ABS is deactivated when the Locker is on(ABS light)
If I made any mistakes in operations let me know. Recently my e-locker failed to work, so I did some reverse engineering to learn about it's operation. Turns out my harness going to the axle got cut somehow, that I didn't spot during my first inspection, but eventually found during my diagnosis.
Click the link from my first post in this thread to see the wiring diagram of the system.
Old Aug 6, 2004 | 05:06 AM
Thanks guys! Let the wiring begin!
Old Aug 6, 2004 | 06:05 AM
Jake-
So do you agree with Bruce's posted schematics in the sense that if I follow that diagram (in his first post) the locker will work? If not, then I need to do some research before I start soldering further. Let me know, thanks!
http://www.tundrasolutions.com/phot.../sort/1/cat/500
Old Aug 6, 2004 | 06:36 AM
Originally Posted by Jake94
but I'm still trying to figure out the diode thing.
Me too. My understanding is that a diode converts alternating current to direct current...so I do not understand why diodes are needed in this case (aren't we dealing with only DC?)
BruceTS's Avatar
Jake-
He said the same thing I just posted, the wiring diagram is correct (verified on my 4Runner) The only circuit it doesn't show is the one going to the ABS to disable it during operation. I like that feature and plan on adding another switch, so I can disable ABS only.
As for the diodes, they act like a one-way valve and are just an added safety feature.
BTW if the image doesn't show, click my signature and it'll take you to my photo album where you can get to the diagram.
Old Aug 6, 2004 | 07:08 AM
I saved it and printed it out. But thanks.
So what type of resistor should I get?
Old Aug 6, 2004 | 10:53 AM
p1michaud's Avatar
Thumbs up Locker wiring.
Thanks for the info guys. I agree with you BruceTS and Jake94, I guess that my explanation did not come out as well as I had hoped. I read your post and agree with it, I just had different terminology. Regardless I have it straight in my head wich is the important part...
Would any of you guys have pics of the finished locker harness? I'm just curious to see. Also, how much wire (length) are you leaving from the diff wiring harness to the ECU in your driver kick pannel?
Cheers!
Old Aug 6, 2004 | 10:57 AM
I have about 6ft of 10 guage wiring. I am only running it to under the drivers seat. My Clifford alarm resides in the footwell.
Old Aug 6, 2004 | 06:30 PM
Ok guys, I am still having a hard time. Following Bruce's posted schematic, here is where I am right now:
IGN 12V power to 10A and 20A wires: OK
GND (7), 4WD (8), LOCK GND: ALL OK
Power (11.72V tested) to RR Diff Lock switch: OK
Power from RR Diff Lock switch to "R" (4) on ECU: OK
So my question is, with the RR Diff Lock button pressed in and power getting to the ECU, there are no other wires leaving the ECU (REL 1, REL 2, M1, M2) with power. Now I am no electrical wizard, but common sense tells me that REL 1, REL 2, M1, M2 all should have some power getting to them.
Am I right?
Please help. This is driving me nuts!
And just to clarify, I am not dealing with the Locked Light right now. I assume that has nothing to do with the diff locking.
Old Aug 6, 2004 | 06:59 PM
Yes, they are grounded. See, my issue is that I do not think any power is getting to the locker right now - otherwise I would get some juice from some of the wires leaving the ECU and heading to the locker - right? I mean, something has to tell it to turn on. That is why I don't get it. I took my multi-meter and checked each connector leaving the ECU, and nothing was hot.
Old Aug 6, 2004 | 07:34 PM
amusement's Avatar
...As for the diodes, they act like a one-way valve and are just an added safety feature....
Zener diodes act as a inline fuse
Diodes couple to a ground state if enough amperage or voltage is applied.
M2 should be hot when the circuit is engergize. Using one voltage meter lead to ground and the other should should show hot, right?
Here's a service manual shot of the elocker wiring
Notice how http://home.off-road.com/~kemanuel/e...ker_wiring.jpg M3 should be M1.
Old Aug 6, 2004 | 08:57 PM
Jake-
I am being pushed in that direction, trust me. I gave up for tonight. Maybe I will hit it again tomorrow.
Again, I am concerned that no power is reaching the locker - at all.
Old Aug 7, 2004 | 09:26 AM
amusement's Avatar
I think this is the best setup ... keep it simple ... my favoriate plan 'A'.
http://www.explorerforum.com/tdavis/zuk/locker.jpeg
Note: Inch Worm has been installing Toy elockers for years so .. if they don't have a relay then why should you. Food for thought.
But, if you have a desire for relays take a look at Mike Carter's setup
http://67.122.16.97/carterman/4runne...r/circuit3.gif
Old Aug 7, 2004 | 11:01 AM
Thanks amusement!
