E-locker light is blinking and won't engage. This ever happen to anyone?
Old Apr 7, 2009 | 01:39 PM
  #41
hawaiibake's Avatar
The door sills were under water on the outside but no water came in. A tonne of it drained out of the body though from somewhere. I can't believe she didn't flop all the way over. would have been half submerged.
Anyone ever fabbed a cable shifter for the elocker? I know they sell one but by the time I pay for the canadian-us dollar and shipping and duty it will be over $400
Old Apr 7, 2009 | 01:40 PM
  #42
CHSrunner's Avatar
^^ I agree. sounds like the e-locker motor/actuator assembly might be shot. might save some hassle to just find a new one.
Old Apr 8, 2009 | 02:36 PM
  #43
CHSrunner's Avatar
Just an idea check out this article. I'm sure the actuator's are very similar from the 4runner and land cruisers.
http://www.sleeoffroad.com/technical...k_actuator.htm
Old Apr 24, 2009 | 07:13 AM
  #44
hawaiibake's Avatar
I took off my locker motor for the tenth time on the weekend to try to get it working. I had been camping and almost didn't get up a steep rocky hillclimb and it totally pissed me off that i had a locker on this thing but couldn't use it. The funny thing is that when I took off the three bolts that hold it on and just held it against the axle, it would work perfectly.
But as soon as I bolted it on and took it for a drive, no dice. So I am going to take the motor houseing apart again and really lube the crap out of it and when I bolt it on I will not tighten it down super tiight and see if that works. I am also sliding the little fork gear thing over to the left just before it locks up before I put the actuator back on.
Old Sep 12, 2010 | 04:16 PM
  #45
jritch's Avatar
Its been over a year since this post, but I'm having the same problem. The light just flashes and it wont lock. I took the actuator off and it turns fine when its out. The gear moves easily when I move it with a screw driver. I locked it, pushed the button in and put it back together and it wouldn't unlock. So I took it back apart and unlocked it. I have no idea why its not working. It makes no sense
Any ideas??
Old Sep 14, 2010 | 05:55 PM
  #46
jritch's Avatar
So now it unlocks and locks when the actuator is loosened off at the top, but when I tighten it, it stops working. I can hear it try to go but it sounds tight, like its binding internally.
I have the bottom 2 bolts tight and the top one a little loose with some lock tight. It works, so that's how it stays.
Good enough!
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
94yotaky
Jul 23, 2015 07:50 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
AaronM
Jul 8, 2015 07:15 PM
