E-Locker 3rd Member with 4.30 to 4.10?
Old Jan 24, 2004 | 02:34 PM
goldtaco9's Avatar
Pardon the obvious lack of knowledge here but if I can find an e-locker 3rd member for my "new" '00, should I be worried about whether it is a 430 or 410? Is this something that is easily changed?
Thanks,
Mike
Old Jan 24, 2004 | 02:37 PM
kyle_22r's Avatar
needs to be the same ratio as the front one, otherwise you're in for some nasty wheel hop and breakage.
Old Jan 24, 2004 | 02:40 PM
goldtaco9's Avatar
Sorry I was so vague there. I undersatnd that the front and rear must match.
What I do not know is whether I should be shopping for a 410 or if I find a good deal on a 430 whether I should buy it and then change it to match my front?
Thanks,
Mike
Old Jan 24, 2004 | 03:51 PM
Albuquerque Jim's Avatar
That depends on how you want to use it, what tires you want to run, etc.
I am going from 4.10 to 4.30 because I want to run taller tires and retain the power.
And, (for those of you that are experienced and might get critical) I know that's not a very big diference. I want to retain the highway manners of a relatively high rearend gear and I will go to a dual case eventually so low rearend gears aren't necessary for what I want.
Old Jan 24, 2004 | 04:18 PM
toy283's Avatar
Yes, you can change the gear ratio if you need to. The electric lockers use the same V6 gears as a non-locked diff.
Old Jan 24, 2004 | 06:46 PM
jx94148's Avatar
If its available get the 4.30 rear and then worry about finding a cheap front diff with 4.30 too. Swapping in a used front diff with the right ratio is about 20% the cost of paying someone to swap gears in a lockes rear. $200 for front diff that you can do yourself with patience vs. $1000ish for rear gear job with expert (necessary) labor.
Old Jan 24, 2004 | 09:48 PM
arjan's Avatar
I'll be picking up an e-locking diff this week. After we agreed on the price I asked him if I could swap my front diff. with one of his to match the gear ratio to one I was getting. He told me he'll get me one and that I don't have to worry about giving mine back,since he has lots of front diffs, and he doesn't sell many.
Something to keep in mind.
Arjan
Old Jan 25, 2004 | 05:17 AM
transalper's Avatar
I like the 4.30s and would recommend swapping in a front diff rather than replacing the 4.30 e-locker gears with 4.10s. Swapping 4.10s into the 4.30 e-locker will add a fair amount to the price. Buying the 4.10 gears and paying someone to set them up may cost more than buying a 4.30 front diff and swapping that in at the same time.
If you just want to lock the rear, I would hold out to find a 4.10 diff unless you want to spend the exta $$. There are usually quite a few 4.10 e-locker diffs on car-parts. Are you going to do the housing mods yourself? If not, dropping in the ARB might be a good way to go, especially if you plan to eventually add onboard air.
Old Jan 25, 2004 | 09:28 AM
kyle_22r's Avatar
if you buy them new, they're all $795 from toyota if i remember right. available in 4.10, 4.30, and 4.56...all the same price
Old Jan 25, 2004 | 10:01 AM
44Runner's Avatar
I could use a set of 4.56s if you find one with that
Old Jan 25, 2004 | 10:02 AM
44Runner's Avatar
why not at least step up to 4.56s? 4.30s just isn't worth the trouble at all. Not to mention it is a hard ratio to find in the after market. Last I heard they stopped making them...
Old Jan 25, 2004 | 10:25 AM
Napoleon047's Avatar
a grand for a gear set up??? where are you going? i know of an ASE 30yr+ gear tech who sets them up for $100-$150 labor if you bring in the third
Old Jan 25, 2004 | 12:16 PM
44Runner, I already found a rolled 99' with a 4.30 locker and the front diff. I am getting a great deal if I take them out.
My plan is not to re-gear. Someday (within the year) I will put in dual cases to handle the gearing.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Patrick1976
Sep 15, 2015 11:33 PM
zz_denis
Sep 6, 2015 03:43 PM
