E Brake Blues
Old Mar 17, 2005 | 07:32 PM
CanDo's Avatar
E Brake Blues
Greetings,
I've done a search on stuck rear bellcranks that won't release. Typically will servicing with lube/solvent fix the problem or are new parts usually required?
It's a 2000 4Runner with much underside corrosion...think salty winter roads.
Any idea of parts and labor to get this done?
How does the stuck pivot affect the self adjusting of the rear brakes?
At present, when the ebrake is applied the bellcrank pivots. When the ebrake is released the pivot remains stuck. I've tapped it backoff with a hammer and don't use the ebrake for now.
Thanks for your help.
Old Mar 17, 2005 | 08:07 PM
CanDo's Avatar
help... anyone?/
any comments/help would be much appreciated.
Old Mar 18, 2005 | 06:42 AM
eric-the-red's Avatar
I had the same problem on another vehicle before, and after cleaning and lubing it 2 times in 6 months ended up replacing the parts. I found I could free it up with WD-40 but it didn't last very long.
old87yota
Oct 25, 2015 02:15 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
bfmcelroy
Aug 18, 2015 06:42 AM
ty1er
Aug 1, 2015 11:53 PM
CanRunner
Jul 20, 2015 01:29 PM
