Dual cat. converter 4runners
Old Nov 29, 2005 | 03:03 PM
  #81
mt_goat's Avatar
Originally Posted by Erich_870
Side note on that. I went to the dealer straight from the muffler joke and asked them to check the CEL. First I was asked if I had bought gas recently The tech said if I have a leak (I'm assuming in the filler neck, letting air in) that it will set it off. I was instructed to open the gas cap, let it sit for 20 sec, close it until it clicks, and then it will take 3-4 trips to clear the light I convinced him that it wasn't on because of that. I wanted to write down exactly which Cat code it is throwing. He said he could fit me in on Dec 8, and it would cost me 1 hour diagnostic time
Thanks,
Erich
Around here you can pop into an Autozone and they will pull the OBDII CEL codes for you FREE. Other major auto parts stores may also do that.
Old Nov 29, 2005 | 03:31 PM
  #82
Erich_870's Avatar
Originally Posted by 4x4Fink
Erich...where did you get the OBDII reader from? I may go ahead and get one myself, thats MUCH cheaper than I thought it was.
Thats ridiculous that they were wanting to charge you so much for checking the CEL.
And yes, you could completely cut off both cats and the computer would work JUST fine.
Fink
This is where I'm ordering from. I haven't had a chance yet today. http://www.obddiagnostics.com/
It's the same one Gadget sells on Underdog Racing.
You hook it up to a Laptop and use the free software.
Erich
Old Nov 29, 2005 | 03:46 PM
  #83
tc's Avatar
tc
The emissions standards are the same, but it is illegal to modify the environmental compliance systems on the vehicle. If it came with 2 cats, it has to have 2 cats. If they don't do a visual inspection though, they will probably never know
Old Nov 29, 2005 | 03:57 PM
  #84
midiwall's Avatar
I've had one of those for about 3 years now. It's a superb value.
I also have one of these which is awesome to carry with in the truck. I use it with a Palm M505 that I bought way cheap on eBay.
Old Nov 29, 2005 | 04:47 PM
  #85
Babypig's Avatar
Or as was stated above, take it to the dealer and have them replace the cats under warranty. * years or 80,000 miles is the warranty term.
Old Nov 29, 2005 | 04:52 PM
  #86
Erich_870's Avatar
I have 93,000 miles, and I belive Fink is well over 80,000 as well.
Erich
Old Jan 15, 2006 | 10:59 PM
  #87
Fink's Avatar
Alright...
This has become an ordeal.
First off, I was sent the wrong set of instructions with the 02 simulator. Thankfully the wire that had to be completely cut was the correct one and the one that I just had to tap into was not.
I have not gone back and fixed it yet but I will do that tomorrow and then I will be able to accurately tell you guys if this fixes the problem or not.
Just thought I would post up with an update. I'll let ya know when I get it finished.
Fink
Old Jan 16, 2006 | 09:50 AM
  #88
cracker_1's Avatar
I have had the same problem w/ our 99 4runner. The code was for the front catalytic converter. Last week, I had the muffler shop take out both cats and I had a Magna Flow put in. So far, no CEL. I have the URD O2 simulator, but I haven't installed it yet. I am waiting to see if the CEL comes on first. Time will tell....
4x4fink, is your CEl still coming on, even after replacing the converter??
Old Jan 16, 2006 | 11:48 AM
  #89
Erich_870's Avatar
Cracker - How many O2 sensors do you have now? The one exhaust shop I talked to in town refuses to do any work with non stock set ups, so I'm still trying to figure out what to do. Luckily, after buying that OBDII tester, my CL hasn't come back on I haven't even used the tester yet! I must have scared it straight
Fink - I'm looking forward to seeing how the simulator works.
Side note: I don't understand why that front cat is so darn expensive? I've found the rear cat for the Cali emissions for $2xx but I can't find the front one anywhere but at Dealerships ($7xx - $9xx)
Erich
Old Jan 16, 2006 | 12:15 PM
  #90
cracker_1's Avatar
Erich
I had sensory in front and a sensor behind the stock catalytic converts. I told the shop to make sure the rear sensor was not more than 12" behind the new cat.
Old Jan 16, 2006 | 02:31 PM
  #91
Fink's Avatar
OK well...this is not making me very happy.
First off...the version of the instructions were sent with my simulator so I tapped into a wire that did not even need to be messed with, luckily I only had to tap into it and not splice into it.
Second, Gadget sent me the new instructions and I went back in today and cut off the sim wire from the bad connection and re-taped it. Got it hooked up correctly this time and about 35 or so miles into driving the Runner, my CEL goes off again
This time the code is:
P0136 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
What's the deal here??? I had no idea it was going to be this big of a deal or I would have dealt with the code I was getting the first time.
I sent Gadget an email asking him what could have caused this and what I should do next and I am waiting to hear back from him.
Anybody have any ideas on what could be going on here? I mean, the install was easy once I got the right instructions. Cut wire, strip insulation, twist together, solder, tape/heatshrink. The only thing that could be wrong is I got the wrong ends going to the wrong connections but I triple checked myself when I was connecting them and I just don't see that as a cause.
*rant off*
Fink
Old Jan 16, 2006 | 04:07 PM
  #92
mt_goat's Avatar
Damn Fink, I'd be frustrated too. Surely Gadget will help you through this as soon as he gets a chance.
Old Jan 16, 2006 | 05:30 PM
  #93
Fink's Avatar
Yeah, I was hoping to hear back from him today but I guess it was too late when I sent the email. I'd really like to hear back from him tomorrow morning as I have my first class of the sem. tomorrow and then after 1:30 the Runner will be at the dealership getting a bunch of stuff done to finish it off.
Thanks for the reply man, I'll keep this updated as I get more info on it!
Fink
Old Jan 16, 2006 | 05:48 PM
  #94
MTL_4runner's Avatar
I understand what you were trying to do, but I don't think you are tackling the P0420 code the way I would. The simulator is just a bandaid even if you were able to get it to work. You may need to get an OBD II tool like the laptop or PDA based types so you can actually see the output of each O2 sensor. You can also clear the OBD codes yourself by pulling the negative battery terminal for a minute or two.
Old Jan 16, 2006 | 05:51 PM
  #95
Fink's Avatar
Well I mean...the reason the code was going off was because the ECU was used to the specs of a CA emissions vehicle and then I freaked it out by taking off a cat so it was obviously a lot worse. Before this whole thing I was under the impression that the only way to fix this conversion between dual cats and a single cat was to either get a new ECU from a non-CA emission spec Runner or go with the simulator. So I chose the latter...I'm hoping this wasn't a bad choice.
Fink
Old Jan 16, 2006 | 06:07 PM
  #96
Fink
New ECU might come with its own set of headaches. I forgot to reread the whole thread again so I redited my post. You really need to see what those outputs look like in order to solve it or just ignore the CEL altogether.
Old Jan 16, 2006 | 06:09 PM
  #97
Fink's Avatar
What would the outputs tell me? I don't have any knowledge of that stuff or the tools, think thats a test my buddies up at the dealership could run?
So are you basically saying that there was no point in doing the simulator?
Fink
Old Jan 16, 2006 | 06:14 PM
  #98
Fink
There should be a voltage spec for the O2 sensors on a cal spec 4runner and you would need to check these against the acutal output of the sensors. You also need to check with Gadget that the simulator was made for a cal spec 4runner since the sensor's acceptable range may be different (I don't know the answer to that offhand).
Old Jan 16, 2006 | 06:30 PM
  #99
Fink's Avatar
Alright, I will write him an additional email about the CA emissions and then wait for his responses tomorrow.
Thanks for the help Jamie.
Fink
Old Jan 16, 2006 | 09:01 PM
  #100
Fink's Avatar
"You probably smoked the thing with the improper connections.
Try resetting your ECU and see if it comes on again.
Just to clarify, you do still have the rear O2 sensor installed in the stock location and in contact with the exhaust gas?
Gadget."
Sounds like he thinks when I used the initial instructions I toasted the simulator. I assume when he says reset the ECU that would be unplugging the battery just like I would to clear codes. If so then I've already done that.
I'm hoping its something as simple as just getting a new simulator but I have a feeling it's not.
I was hoping for a more descript response but I guess not.
I'll see if he writes back again tomorrow.
Fink
