drl on Canadian 2 Gen. 4 runner
Old Dec 15, 2004 | 04:04 AM
Slowrunner's Avatar
I would like to disconnect my day time running lights on my 1990 4runner. I searched all the forums but nobody actually shows how to do it. I only know that the modular is behind stereo in the dash but thats it. When I start her up everything lights up even my dash lights.The only time I flick my light switch is to activate my high beams. I already went through a couple of head-lights in a year. If any Canadian 2 gen.4runner owners done this please tell me how.
Old Dec 15, 2004 | 04:58 AM
4Hummer's Avatar
Bump Me too.
The only thing I can do is turn my dash lights on or off
Old Dec 15, 2004 | 07:46 AM
eric-the-red's Avatar
Looking at the wiring diagrams it should be possible to do by disconnecting the ground at the DRL resistor. That's the square thing on the driver side inner fender, just behind the coil, with the "HOT" label on it. The DRLs are grounded through this resistor to make the voltage lower at the lights. If the ground is interrupted, either by a switch or wire cutters, the lights won't go on.
This is only a theory, so you may want to just disconnect it temporarily before doing anything permanent. The green/white wire is from the lights and the black/white is the resistor ground, though it shouldn't really matter which one is disconnected.
And if something catches fire or blows up you didn't get this advice from me
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
