Driveshaft center bearing flange nut
Old Jul 5, 2005 | 10:11 AM
DaveInDenver's Avatar
Anyone know if the stake nut that retains the flange holding the carrier bearing on a 2-piece driveshaft is the same or similar to the pinion nut on the third? I need to replace the carrier bearing, but apparently no one has the nut in stock. I have an extra pinion nut and was hoping that it was the same diameter and pitch, but that the staking shoulder is taller or something.
Old Jul 5, 2005 | 10:36 AM
4Crawler's Avatar
Yep, should be the same thing.
Old Jul 6, 2005 | 06:53 AM
Took it all apart last night and the pinion nut I have did not appear to be the same size. I did not take my old companion flange nut off to compare, though. I'm gonna wait on the one my parts guy ordered and compare them before proceeding.
Old Jul 6, 2005 | 07:27 AM
4Crawler's Avatar
Interesting, the t-case and pinion flange nuts are all the same size, 30mm nuts. Never seen the center support bearing nut, though.
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
JimiJams
Aug 7, 2015 01:36 PM
Up&Down
Aug 5, 2015 06:20 AM
TDonkey
Jul 26, 2015 10:14 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
