Driveshaft on 2WD
Old Apr 19, 2004 | 04:06 PM
crazybout4runners's Avatar
Unhappy Driveshaft on 2WD
Hey,
Has anyone out there had any problems with a 94 4Runner driveshaft.
I have a rumbling coming from under the truck, and I initially though it to be the rear end. I replaced it with a 95 rear end with 32,000 miles, but the rumbling is still there. The shaft is within the .030 in round out, and when I run just the engine and trans, there is no rumbling. The rumbling starts at about 50mph and gets worse and the speeds increase.
Any Ideas?
Thanks
Old Apr 19, 2004 | 04:37 PM
CTB's Avatar
CTB
Originally Posted by crazybout4runners
Hey,
Any Ideas?
Thanks
U-joints gone bad?
Old Apr 19, 2004 | 04:41 PM
I replaced both u-joints, and that seemed to quiet the problem a bit, but the rumbling is still there.
Thanks for the reply
Old Apr 19, 2004 | 04:50 PM
anthony1's Avatar
More info on your runner would be nice....got lift? how much?
Old Apr 19, 2004 | 05:35 PM
It's factory standard. I purchased it about 2 months back. I don't believe it has every seen off road.
Old Apr 19, 2004 | 11:27 PM
superjoe83's Avatar
does it have a one or two piece driveshaft? if its got a two piece, then that sounds like a center support bearing or also called a carrier bearing going bad
Old Apr 20, 2004 | 07:56 AM
anthony1's Avatar
Maybe your tires are out of round.
Another thing to check is maybe one of the axle is bent.
put the rear alxe on jack stands and put in gear and see from the back if you notice anything.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Flightguy
Oct 2, 2015 05:34 PM
Cycles
Sep 29, 2015 06:37 AM
