driver side lean
Old Dec 19, 2008 | 07:49 AM
defyota's Avatar
driver side lean
my 1998 tacoma has a decent driver side lean. I put in the front strut lift and a rear aal and the lean didnt change. is there any thing i can do without dumpin money on new springs
Old Dec 19, 2008 | 07:53 AM
97ltd4x4's Avatar
Are the springs seated correctly? Also there is a drivers side spring and passenger side one...Did they get mixed-up?
Old Dec 19, 2008 | 07:56 AM
defyota's Avatar
yes the springs are seated correctly , but i dont know if the springs got swapped tho. how can i tell which side is which
Old Dec 19, 2008 | 09:35 AM
spacewrangler's Avatar
which aal pack are you using? i know deavers aren't side specific.
unless you have adjustable coilover's ...or a leaf pack that takes into account the extra drivers side weight, there's not much you can easily do.
Old Dec 19, 2008 | 09:39 AM
BajaRunner's Avatar
i have a lean on my drivers side too.
Old Dec 19, 2008 | 10:04 AM
deines97runnah's Avatar
I feel like every truck i own or sit in has a driver side lean. the runner "Feels" like it leans on the driver side esp. when i make right hand turns....but i think its just because i am the only one in it and seats a little flat on the left hand side.
Old Dec 19, 2008 | 10:07 AM
i think the 4runners have the battery, gas tank, and driver all on the driver side just like the tacoma.
Old Dec 19, 2008 | 10:56 AM
defyota's Avatar
so the lean problem is the in the rear springs? i figured it would be up front
Old Dec 20, 2008 | 05:52 AM
it's not the springs, front or rear, that's causing the problem. the issue is that you have the same spring rates on the drivers and passengers side ..but there is a lot more weight on the drivers side. ...so it leans to that side.
you can get some alcan or dakar leaf packs that have more arch on the drivers side spring pack ..this takes into account the extra weigh on the drivers side and will level it out.
if you have adjustable coilovers, you can also crank the driver side up a quarter inch or so more than the passenger side and that will get rid of the lean.
Old Dec 20, 2008 | 07:34 AM
scuba's Avatar
thefishguy77
Jul 30, 2015 10:59 AM
CanRunner
Jul 20, 2015 01:29 PM
msane99
Jul 17, 2015 10:13 AM
razorman8669
Jul 12, 2015 12:13 PM
crashburnoveride
Jul 10, 2015 06:39 AM
