drive shaft question
Old Oct 22, 2002 | 02:03 PM
swerks's Avatar
Question drive shaft question
with my truck in neutral and the parking break on, I have a good inch of play in my rear drive shaft. Is this normal???
Old Oct 23, 2002 | 09:12 AM
loosehead's Avatar
Is this still related to the clunk noise/tranny problem question? I don't think you should have that much play in the drive line. I am still guessing its one of the U-joints. You can see how much play is in the rear axle/pinion by blocking the front wheels, putting the rear axle on jack stands, and put it back in nuetral. Crawl under there and sutrn the drive shaft to see how far it turns before the tire turns. If you have someone who can help you, you can hold the driveshaft and have a helper slowly turn the tire, and watch how much play there is in everything, and hopefully isolate the problem. There should be a small amount of play in both the axle and tranny, but if it moves alot beyond that, then theres something else wrong. The next weekest link is usually a U-joint. Good Luck.
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
