Dr. Z - ECT Mod
Old Apr 9, 2003 | 09:49 AM
broknlgs24's Avatar
Dr. Z - ECT Mod
i've been reading about the above mentioned mod and was wondering if u all would know if this is possible on motorcycles?
Old Apr 9, 2003 | 12:57 PM
Dr. Zhivago's Avatar
Away
As long as you're talking about water-cooled, EFI motorcycle engines, then yeah, it'll work.
Modern, 4-Stroke EFI engines, controlled by an ECM (ECU) all function basically the same way.
The only thing you'll need to figure out is the resistance curve of the ECT Thermistor for the engine in question, which will determine the required resistance change or value.
Hope this helps.
Dr. Z
Old May 27, 2003 | 05:06 PM
pfdaxe's Avatar
Ok...to all 2000 Runners.
I finally did the ECT mod this past weekend....yeah.
The wire to cut will be different than in Dr. Z's write-up. Maybe because he has a 5spd??
Anyway...below is a pic of the wire (Green one I seperated in the center)I ended up splicing into. On the ECT connector...the ECT side had a Green and Brown wire. On the harness side were a Green and Blue w/ Black stripe wire. I put an ohm meter on the Green wire and in the pic is where I found it on the ECU.
Old May 27, 2003 | 05:07 PM
rimpainter.com's Avatar
Paul-
What do you think of it?
Old May 27, 2003 | 05:13 PM
pfdaxe's Avatar
Alittle bit peepier. Still have slight ping though. I know that has to do with the ˟˟˟˟˟ 91 octane around AZ.
Old May 27, 2003 | 05:18 PM
There is a 76 by the autoplex, and I think one on Bell and 56th that has 93 oct. I would have to verify that though.
TheBFA
Feb 15, 2020 06:55 AM
Longbed 90
Oct 19, 2015 11:05 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 20, 2015 06:15 PM
