Double Cab Rear Sway Bar
Old Nov 19, 2002 | 06:27 PM
tomus1000's Avatar
Originally posted by BajaTaco
Do you plan on using the sway bar off-road? And if so, have you given any consideration to the effects it will have? I'm not trying to be a jerk, just wanted to make sure you evaluated that.
What are the effects of using the sway bar off road? I do use the truck off road. Should I not be considering this mod for my truck?
Old Nov 19, 2002 | 07:14 PM
CTB's Avatar
CTB
Decreased articulation
Old Nov 19, 2002 | 07:22 PM
tomus1000's Avatar
Oooooh. Decreased articulation. I should have known....
And why, again, is decreased articulation a bad thing?
Old Nov 20, 2002 | 06:33 AM
trdtacoma01's Avatar
As far as I know, decreased articulation is not good if youre doing hardcore offroading. It decreases the chassis/frame flexibility thus making it harder to offroad under certain conditions. I personally dont do much of it, so for me its perfect.
Old Nov 20, 2002 | 07:44 AM
  #25
jalaber's Avatar
decreased articulation is bad b/c you will lift a wheel earlier while off-road thereby reducing traction. While not a Taco you can look at my handling page to see the before and after effects of adding heavy duty sway bars. For someone who goes off-road infrequently the rear sway bar can be removed relatively quickly for that off-road trip. The front bar can use sway bar disconnects.
Old Apr 10, 2003 | 09:01 AM
  #26
Jeff B's Avatar
Has anyone else installed one of these?
I 'm having trouble locating the U bolts and brackets on the axel, the brake lines are in the way. A picture would be great!
Thanks- Jeff
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
Nickdigg
Jul 7, 2015 06:04 AM
elwood73
Jul 5, 2015 07:07 AM
Vargntucson
Jul 4, 2015 12:15 PM
