Doing the unthinkable (going 2wd)
Old Feb 8, 2005 | 11:34 AM
NathanBERG's Avatar
Talking
Originally Posted by Praufet
As I read more and more about prerunning it seems its predominatly filled with 2wd vehilcles and the total choas site even recommends removing the front diff for extra travel. So here's my questions:
1.Would I just need to get the rear transmission housing, driveshaft and fronts spindles from a 2wd 4runner to convert it, or am I missing something?
2.Could I get any money for my 4wd parts? if so any ideas how much?
This is my last post fro today, thanks for your patience.
JUST SAY IT AINT SO!! :pat:
Old Feb 8, 2005 | 12:00 PM
drabnor's Avatar
i have a tacoma v6 prerunner transmission with ~80k mi. if you are interested. im in socal and would let this thing go for $200 obo
Old Feb 8, 2005 | 12:02 PM
EWAYota's Avatar
with the total chaos kit and similar kits, i know that they recommend smaller tire sizes, 31 or 33's which allow for the added travel to occur. if you have the room above and around the tires, ie: cut out fenders or fiberglass, added lift with either suspension or body, would you be able to get the same amount of travel with 35's? and would the kit be strong enough for tires that large?
Old Feb 8, 2005 | 12:43 PM
Praufet's Avatar
I have chosen to go a different route. Cruiser coils, custom diff drop, custom bj spacers, custom panhard stuff, marlin brake lines, ome shocks all around and hopefully 33s or 35s or somewhere in between :-D
Old Feb 8, 2005 | 12:51 PM
  #25
deathrunner's Avatar
If you want to convert to 2wd, simply rake out the diff and drive shaft and axles and cur some soup cans as caps for your spindles. That's it!
EWAY the kits are strong enough for 35's but your axles/cvs might not be. I'd stick with 33's.
You can go almost as fast as a 2wd prerunner if you're setup right. my front end is running torsions and my rear is far from setup, watch how this stuff works. I say keep the 4wd
videos: www.sethmetal.com/deathrunner.htm
Old Feb 8, 2005 | 03:34 PM
  #26
VolcomTacoma's Avatar
With the Total Chaos kit you have to get fiberglass front fenders to clear your tires no matter what. The arms are 3.5" wider per side. 33's would be optimal, but you can run 35's with some firewall clearancing. The tires won't limit travel but just clearance themselves if you don't have enough room. The kit itself is plenty strong enough for 35's.
ladybugRC
458
Aug 21, 2020 10:41 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Flightguy
Oct 2, 2015 05:34 PM
Cycles
Sep 29, 2015 06:37 AM
