Do your trucks/4runners wander?
Old May 12, 2007 | 09:13 PM
Mad Chemist's Avatar
Hey, I'm up in Lake Forest Park. Also have the same issue with my '98. Front end alignment helped a bit. My Revo's seem to wander on me alot more than when I've got the 33" MTs on the rig. I'm thinking about trying new bushings on the a-arms to see if that helps.
Old May 13, 2007 | 08:28 PM
RunnerUp's Avatar
my truck used to wander when my mud terrains had about 40k on them, replaced them with terragrapplers and problem was gone
Old May 13, 2007 | 09:41 PM
nick-m's Avatar
Mine drives straight on even terrain, but Lord help me if I hit a big pothole at highway speed - that usually throws it hard in one direction or the other. I have new and properly balanced tires, so it's between the steering bushings, which are relatively inexpensive to replace, and the suspension being shot, which I know for a fact is.
Old May 14, 2007 | 12:16 PM
CLin9383's Avatar
wa4x4 any update? my steering wheel is wobblying alot and when i hit bumps i feel like im on ice bouncing around!!
Old May 14, 2007 | 12:33 PM
  #25
Gerdo's Avatar
Over the last couple of years I have replaced: Steering Rack, Inner and outer Tie Rods, Poly Steering Rack Bushings, Poly front Anti-Sway Bar mounts and end bushings, Rear Anti-Sway Bar end bushings. I also keep the tires rotated and ballanced. My Bilsteins are in good shape also. It rides great and goes straight down the highway better than most new cars.
Old May 14, 2007 | 12:48 PM
  #26
cackalak han's Avatar
My 98 wandered like crazy, too. Hitting a pot hole at anything over 40mph sent the front end hopping all over the place.
I switched out the struts/shocks, but didn't remedy the problem. I was going to get new steering rack bushings, but it was totalled before I could do that. Also did new sway bar bushings, endlinks, but didn't help.
It's probably the steering rack bushings, ball joints or tie-rods.
Kcannaday
40
Mar 26, 2021 05:59 PM
Ricu_air
Sep 21, 2015 08:09 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
ashersullivan88yota
Aug 23, 2015 12:49 AM
ashersullivan88yota
Aug 12, 2015 01:16 PM
