Do I need a Transmission cooler?
Old Nov 25, 2002 | 08:02 AM
CBDenver's Avatar
All,
I've seen the transmission cooler kits you can install easily and for cheap it seems.
I don't tow (hardly ever), and am wondering if I should put one of these on my 97 4Runner?
Anyone have any thoughts on this and suggestions?
Thanks,
Chris
Old Nov 25, 2002 | 08:07 AM
CTB's Avatar
CTB
Are you supercharged? If so, then I would say go for it. Either way, it is only going to be good for your tranny. However, if you aren't supercharged and don't ever tow, it probably isn't a big deal.
Old Nov 25, 2002 | 08:11 AM
CBDenver's Avatar
Thanks for the reply. I'm not supercharged, but drive hard in the mountains. Just wondering if it would be good preventative measure to do for the price?
Thanks again.
CB
Old Nov 25, 2002 | 08:14 AM
CTB's Avatar
CTB
Well, I'm sure it couldn't hurt. Preventative maintenance is always a good thing...especially since the coolers aren't too expensive.
Old Nov 25, 2002 | 08:54 AM
loosehead's Avatar
Hey Chris-
I am thinking about adding one as well. I'm like you, I don't tow, but drive in the mountains. I think it would be a good preventative measure...
Old Nov 25, 2002 | 09:01 AM
jacksonpt's Avatar
Senior Member
I don't drive in the mountains, but I do tow . I put a TRD cooler on my rig last summer. If you're not sure if you need one, but think it might be a good idea, pick up a Hayden cooler. They are good coolers (rumored to be the same ones as the TRD coolers) and very inexpensive. I don't think $50 and a couple hours of your time to install it is a big deal for a preventative like this.
Bottom line, you probably don't NEED one, but adding one can only help. They are cheap and easy to install, so why WOULDN'T you add one?
Old Nov 25, 2002 | 09:09 AM
CBDenver's Avatar
Loosehead,
Yeah, I'm prob. going to go ahead and get one and do it. Anything to help extend the life of an auto trans. would be good. Jacksonpt mentions Hayden. Does anyone have any advice on which one to buy? Easiest to install and fit?
Thanks,
Chris
Old Nov 25, 2002 | 09:12 AM
Bob_98SR5's Avatar
(Idiot suit on)
Hope this question is not too stupid, but can manual transmissions benefit from the tranny cooler as well?
Bob
Old Nov 25, 2002 | 09:14 AM
CBDenver,
You can buy a Hayden Transaver Plus . I got the one rated for 30K lbs. (FYI, I am supercharged). There is a write-up on the tech section on the install.
Old Nov 25, 2002 | 09:18 AM
HBoss's Avatar
CBDenver & CTB,
For the time being I don't tow but I take a lot of trips in the mountains too. I did it just for the "preventative maintenance" reason. I'm still glad I did and I would recommend it for you guys too.
Old Nov 25, 2002 | 09:45 AM
loosehead's Avatar
Originally posted by Bob_98SR5
(Idiot suit on)
Bob
Bob,
Manual trannys don't "pump" fluid like an auto, so there would be no way to make one work by gravity flow. As long as you check and change the fluid according to the recommended intervals, much like the axles, you should be fine.
Old Nov 25, 2002 | 01:34 PM
CTB's Avatar
CTB
To add to loosehead's post,
The gear oil in a manual tranny is a lot thicker than ATF fluid and would be a lot harder to pump. Additionally, a manual tranny doesn't get as hot as an auto does.
Old Feb 6, 2015 | 03:27 PM
Pajero2593's Avatar
Hi i am new here I have a 98 taco an can I put a in a external trans cooler an by pass the one in the radiator.
Old Feb 6, 2015 | 03:31 PM
rworegon's Avatar
Yes you can.
Old Feb 12, 2015 | 02:34 AM
ARB1977's Avatar
I don't tow nor drive in the mountains. I still use a external ATF cooler.
irv
Oct 1, 2015 09:49 PM
ToyotaMD
Sep 22, 2015 06:28 AM
briholt
Sep 20, 2015 10:26 PM
TransAmBandit
Sep 20, 2015 06:08 PM
kelly1450
Sep 2, 2015 12:29 PM
