DIY Windshield Washer Fluid?
Old Jan 28, 2014 | 06:04 PM
gratpj's Avatar
Might be a dumb post, but here goes...
Anyone ever concoct DIY windshield washer fluid? (esp. anti-freeze)
Anything wrong with a Windex/water mix?
No, I don't mind a trip to the local parts store for a cheap bottle of the stuff, but last I checked (and it's been a while), they didn't have the kind that won't freeze (because I'm not in an area where that is a concern). However, I do travel to places where that's important.
Just wondering if anyone has any clever tips, ideas, etc. Otherwise, guess I'll buy some next time I'm in a colder climate.
Old Jan 28, 2014 | 06:34 PM
Roark's Avatar
Just tossing it out there.. I've read before (I think) that by adding something with a low freezing point, think ethanol/alcohol, to the wiper fluid will help prevent the freezing. Just buy the cheap fluid from the store and add some of your favorite vodka! Hahaha, or just add any form of alcohol. In theory, it would work.
Old Jan 28, 2014 | 06:48 PM
Inferno451's Avatar
Wiper fluid (at least here in Idaho) already has freezing protection down to about -35F, and it only costs about $2 a gallon. I'm not sure i see much to gain making your own.
Old Jan 29, 2014 | 01:33 PM
Keith B.'s Avatar
Even with the cheapest booze, making your own will not be cheap.
The commercial 0ºF or minus 15ºF stuff has methanol in it. Price out a gallon of 99% methanol.
I've added ammonia or Windex-type stuff in the past here in warm California, but the Windex isn't anti-freeze, at least not much.
Just remember to pick up a few gallons of the anti-freeze stuff the next time you're in one of the colder-winter areas, or see if you can web-order it.
Buy this and never run out:
http://www.amazon.com/Gunk-Windshield-Washer-Solvent-Anti-Freeze/dp/B009JCTMQI/ref=sr_1_13?s=automotive&ie=UTF8&qid=1391034700&sr=1-13&keywords=windshield+washer+fluid+anti+freeze http://www.amazon.com/Gunk-Windshield-Washer-Solvent-Anti-Freeze/dp/B009JCTMQI/ref=sr_1_13?s=automotive&ie=UTF8&qid=1391034700&sr=1-13&keywords=windshield+washer+fluid+anti+freeze
Old Jan 29, 2014 | 04:36 PM
gratpj's Avatar
Originally Posted by Keith B.
Old Jan 29, 2014 | 05:50 PM
CJM's Avatar
CJM
an entire drum lol.....
Old Jan 30, 2014 | 06:19 AM
Texas_Ace's Avatar
The standard blue washer fluid you see is very simple and not worth trying to duplicate.
All it is is water and methanol with a little dye in it. Thats it. The temperature rating on the fluid is determined by how much methanol is mixed into it. -40 is approx 50/50 and +32 is 0% methanol. Everything in between is a linear mix that you can more or less calculate.
Just buy the stuff from the parts store, meth injection guys have tried for years to make it cheaper but it generally comes out the same or more depending on methanol prices.
Personally I like the Rain-X orange fluid that you can get from walmart. The extra additives work nicely and do help with streaking.
Old Jan 30, 2014 | 11:55 PM
reaj's Avatar
I second the rain x orange have that here in colorado works great with melting the snow (we're getting 5-10 inches tonight cookie time) this helps too best $80 bucks ever spent!
http://www.alphathermusa.com/heated-wash-AT-38OD.html
Old Jan 31, 2014 | 03:18 AM
Robb235's Avatar
If you're local auto parts stores don't stock any wiper fluid for below freezing temperatures (like in south Georgia where I'm currently located), go to Lowes or Home Depot. They should have a "premium" grade washer fluid that's good to -30 or something like that.
Old Jan 31, 2014 | 04:16 AM
Texas_Ace's Avatar
If your issue is lowering the freezing point, a simple fix is dumping a bottle of rubbing alcohol into the washer fluid, or if you have access to methanol that works better.
Old Jan 31, 2014 | 06:04 AM
Robb235's Avatar
Or a bottle of HEET. It's pure methanol.
Old Jan 31, 2014 | 07:06 AM
Texas_Ace's Avatar
Yep, that works as well although pretty pricy generally.
Old Jan 31, 2014 | 08:01 AM
highonpottery's Avatar
Rubbing alcohol trick works great as quick remedy. I don't have to worry about freezing here in ca but have to do this when going to the snow or it freezes up in the lines.
My uncle told me about the rubbing alcohol trick - it's what he tells his physical therapy patients to do for making their own cold packs -- the alcohol lets you super cool water bags and they won't freeze unless too little alcohol.
Old Feb 4, 2014 | 10:56 AM
gratpj's Avatar
Almost missed this. That looks like a great buy! Thanks for the tip.
Old Feb 6, 2014 | 07:41 PM
MistaMota's Avatar
I live in Saskatoon, Canada... i use rainx winter formula. 2.99 for 4L the wind chill this week and last got to around -50c and it was still liquid..
synthetic oil on the otherhand did turn a little thicker. but after being plugged in she started right up
Old Feb 8, 2014 | 05:37 AM
wyoming9's Avatar
Red face
Rain-x Orange by the case!! and Done.
I mean if your really bored and missed out on High School Chemistry have at making your own .
Old Feb 8, 2014 | 08:00 AM
reaj's Avatar
Yeah gratpj check them out, love my Alphatherm fluid heater! Sucks a lot of power at start-up but well worth being lazy in the snow and letting the wipers and heated Rain X orange do all the work!
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
bradahman
Oct 1, 2015 09:24 AM
bryan34w
12
Sep 30, 2015 02:50 PM
beltcutter
Sep 30, 2015 06:14 AM
