disrupting trac control in 2wd runner**
Old May 16, 2009 | 06:19 PM
Sea.Jay's Avatar
ok ok so 2002 4runner, 2wd.
im used to pulling this plug out...the one directly below the brake fluid res.
when i pull this my gauge lights up like so...
signaling that abs is interupted and the traction control system is not working.
what id like to do is wire in a switch between the abs module and this plug so i can stop having to pop my hood and pull the fuse or unplug this signal wire.
this last picture is of the amperage of both abs fuses. i believe the 60A fuse is for the abs module itself and the 20A is for the ABS signal.
so would i be golden using a 20A rocker switch?
also there is 3 wires...red, black, white. im guessing white is signal, black is ground, and red is hot?
Old May 17, 2009 | 05:44 AM
crolison's Avatar
I wouldn't use a rocker switch to hold 20A, i'd use a relay.
Old May 17, 2009 | 01:59 PM
eric-the-red's Avatar
You need to do the 'Andy mod'
https://www.yotatech.com/forums/f127...ystems-103814/
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
aowRS
Sep 13, 2017 08:22 AM
urabus
Nov 10, 2015 07:38 PM
87SR5justin
Sep 15, 2015 06:48 PM
May-39
Sep 6, 2015 01:05 PM
