disabled daytime running lights....now have a question
Old Aug 29, 2005 | 04:28 PM
  #41
VolcomTacoma's Avatar
On the contrary has anyone enabled/added DRL's on their Tacoma or 3rdGen 4runner?
Old Aug 29, 2005 | 05:03 PM
  #42
HappyPills's Avatar
Originally Posted by KGnagey
All fuses are good - double checked them. I even pulled the bat cable again for 15 - 20 min to reset the computer. No luck. Is there a DRL relay I'm missing somewhere?
Yes, There are two relays. You only need to cut the wire from one of them which you allready did.
Old Aug 30, 2005 | 10:59 AM
  #43
jforjonathan's Avatar
Originally Posted by 4-RUNNIN' FREAK
This may be the only mod that has never caused me an issue. I never had the high beam light on at all only if I have them on.
When you have the HID's, the reduced voltage for the DRL's would cause the HID's to strobe.
well i cant figure it out. hopefully it wont cause any problems when i get the hid kit. 4-runnin' freak.....do you have pics of the hids on your 4runner? how do you like them? is there any glare or hot spots?
Old Aug 30, 2005 | 03:57 PM
  #44
4-RUNNIN' FREAK's Avatar
Negative on the pics. I didn't have any glare or hot spots, and the cut off angles were good, no stray light scattered and blinding people.
I took them out a while ago, and tried to put them in and they won't stike up anymore. I don't know if the ballasts burned out, or the lamps.
Same thing happened to one of the other 3 kids that have the same package. He took them out and put them back in the box, and went to put them on his motorcycle, and they didn't work.
THe light is freaking amazing. I had the blue tint, and they lit up street signs so bright and crisp. People were flashing highbeams at signs on dark roads, while I could read them from a good distance away.
Old Aug 30, 2005 | 09:23 PM
  #45
thats cool man. i just ordered my hid kit today. cant wait till it comes in!
Old Aug 30, 2005 | 09:28 PM
  #46
From? Color temp? How much? (if ya don't mind)
Old Aug 31, 2005 | 12:46 PM
  #47
i ordered the 6000K kit from xenondepot.com. they went for $449
Old Oct 6, 2005 | 03:59 PM
  #48
AZBlackTacoma's Avatar
Im not sure if this has already been answered but, I have a 4300K HID kit in my 01' Tacoma and I hate the fact that they are always running (Being that the DRL's are active) I was wondering is it ok on the parking brake to pull it in 1 click when driving so my DRL's turn off, or will my brake burn up? Any hel is appreciated. Thanks.
Old Oct 6, 2005 | 07:50 PM
  #49
Anyone?
Old Oct 6, 2005 | 07:56 PM
  #50
arjan's Avatar
I am sure 1 click isn't going to be a problem. Did you ever think about following the ebrake switch wire? It must go to a light relay. You can probably trick the light relay into thinking the ebrake is up. Just a thought.
Old Oct 6, 2005 | 08:20 PM
  #51
That thought did cross my mind, but I was hoping there was a DRL Relay under the hood I could pull but no. Also I tried pulling the 7.5Amp fuse for my DRL but no again. Damn these infernal DRLs
Old Oct 7, 2005 | 11:46 AM
  #52
did you check under the dash right above the gas pedal. on my 02 4runner, the daytime running light relay assembly is right there. you just gota cut the 2nd wire.
Old Oct 7, 2005 | 12:11 PM
  #53
I had to cut the wire for my HID's (as was just said). They are since gone, but no more HID's unless I connect the wire.
My HID's would strobe from the reduced voltage of the DRL. Bad for HID.
Old Oct 7, 2005 | 09:10 PM
  #54
I didnt get a kit like yours. Mine came out of a totaled Cadillac CTS-V. Mine wires directly to the battery and through some relays. No flickering for me!
Old Oct 9, 2005 | 08:29 PM
  #55
Thats how mine wired up too. It was a real kit, except the bulbs were made to fit the stock location so you didn't have to hack up the whole thing.
Had the casper shield built in.
Old Oct 9, 2005 | 10:27 PM
  #56
yozhik83's Avatar
Angry DRL mod on 2000 SR5 SPORT
I did the DRL mod on my truck and I enjoy it very much, but ever since I have performed the mod, that nifty little feature that turns all the lights off upon exiting the vehicle doesn't work anymore. I have killed my battery several times since the mod due to the fact that I never before had to turn off my lights. I am getting better at it now, but would eventually like that functionality back. If anyone has any ideas for me that would be great. I still want to keep the DRL's disabled but I also want my lights to turn off when I open the door.
Old Oct 10, 2005 | 11:51 AM
  #57
Heres the color temp of my lights! 4300K
Old Oct 21, 2007 | 11:48 AM
  #58
02Surf SSR-X 4xSport's Avatar
https://www.yotatech.com/forums/f127...96/#post917477
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
Cplmike
Jul 8, 2015 08:47 PM
