disabled daytime running lights....now have a question
Old Aug 26, 2005 | 05:39 AM
jforjonathan's Avatar
Originally Posted by 90
I think the reason some do and some don't has to do with local bylaws / insurance reg's. I remember reading awhile back, sorry i can't tell u where, that here in Vancouver it was to be made mandatory for vehicles manufactured after a certain date, to have DRL's. Makes sense, it rains pretty blindingly here sometimes.
yeah i think in canada...you have to have DRL. pretty much every car i saw there had them
Old Aug 26, 2005 | 06:09 AM
TBob's Avatar
Ya know you can turn the truck off - put the ebrake on and restart the truck and the DRL will be off untill you re-lease the e-brake.
-TBob
Originally Posted by DavidA
The only thing I don't like is you can't park and run the engine without them on. Sometimes you want only the engine and the air conditioner on while kissing your girlfriend, don't need those lights to draw attention ya know???
Old Aug 26, 2005 | 06:24 AM
RandyÄ's Avatar
Answer is.. ground ecu side
Originally Posted by jforjonathan
k i wont ground it. thanks man. i guess i'll just have to live with teh stupid light. i hope it doesnt get any worse....like be stuck on all the time.
and to all you other guys that are for the daytime running lights....thats cool. i know its a safety feature....and it will make it easier for people to see me on dark or rainy days, but im gonna get hids....and you cant have DRL with hid's. when its dark or rainy...i usually turn my lights on anyway
Ground the ecu side wire. The one from the plastic plug in your pic. Below is the actual TSB which calls for pulling the pin and replacing it.
I did the cut wire on mine a long time ago, with grounding, with no problems.
TSB page here
Old Aug 26, 2005 | 06:41 AM
DavidA's Avatar
Thanks TBob!!! that will come in VERY handy.
Old Aug 26, 2005 | 08:05 AM
  #25
Beartracker's Avatar
David is a happy camper ..er , ah...I mean "lover" now,Lol
Old Aug 26, 2005 | 08:26 AM
  #26
TSB page here
cool thanks man...
so just extend my wire from the plastic harness and ground it to a nut or something like a bolt? happypills told me to not ground it though. so just do like it says to do with the avalon right? i hope this fixes the problem!
Old Aug 26, 2005 | 11:37 AM
  #27
HappyPills's Avatar
cool thanks man...
Yes
Let us know if it works. All the things I have read on this, says you only need to ground the wire if the lights still come on after the wire has been cut.
Old Aug 26, 2005 | 11:42 AM
  #28
Originally Posted by HappyPills
Yes
are you talking about the headlights or the hi beam indicator light that still comes on after cutting the wire?
Old Aug 26, 2005 | 12:41 PM
  #29
well...i just grounded the wire coming off the plastic harness....and it didnt make any difference. the hi beam indicator still came on when i started it and turned off right away. i wonder what else i can do...
Old Aug 26, 2005 | 06:55 PM
  #30
HappyPills's Avatar
The headlights.
Old Aug 26, 2005 | 07:06 PM
  #31
Scofco's Avatar
I've never seen anyone with a 2nd gen mention DRL's before...
Did they come on 2nd gens in the states? My truck has them but perhaps it was just for Canadian models? I'm curious now.
Old Aug 27, 2005 | 09:05 AM
  #32
i dont think the 2nd gens came with them. only on Canadian models
Old Aug 27, 2005 | 10:07 AM
  #33
arjan's Avatar
The 2nd gens only had them in Canada, I bypassed them on both my '91s I had. My '97 I did this too.
On the '91 the DRL relay gets a signal from the ebrake, they stay off when you start with the ebrake on. I took that wire and tied it to ground or 12v. I can't remember. Anyway, the DRL relay never knew I released the ebrake, and the DRL's stayed off.
Another option is to use a 3 way switch so you can turn them back on as required.
Old Aug 27, 2005 | 06:37 PM
  #34
TheFog's Avatar
I did the wire disconnect mod and I had the hi-beam indicator glow dim too. Funny thing is I reconnected the wire back and the hi-beam indicator doesn't glow but my DRLS are still disabled. Maybe I broke it.
Old Aug 27, 2005 | 08:35 PM
  #35
hmm thats weird. at least it worked out good for you! hahaha. knowing my luck, if i reconnected my wire....i bet the drl's would come back on and the light would still be dim. how come you reconnected the wire anyway?
Old Aug 29, 2005 | 01:35 PM
  #36
BikKat's Avatar
The reasons that I will soon be switching (adding a swtich to control my DRLs) are:
It is nice to have control of the lights,
- to signal that moron that forgot to turn on their headlights
- to signal trucks that it is ok for them come over into your lane on the highway
- to drive into a camping area and turn off head lights and not wake everyone in the camp ground up
- to turn off head lights in severe fog/blizzard situations where even the head lights are causing too much glare
- parking/necking in the vehicle with lights on as stated earlier in this thread
I do plan on using them during the day when there is clear sunlight, but if it is overcast or just a slight bit dark, I will switch them off and use my headlights.
SLG
Old Aug 29, 2005 | 02:30 PM
  #37
4-RUNNIN' FREAK's Avatar
This may be the only mod that has never caused me an issue. I never had the high beam light on at all only if I have them on.
When you have the HID's, the reduced voltage for the DRL's would cause the HID's to strobe.
Old Aug 29, 2005 | 03:21 PM
  #38
KGnagey's Avatar
SLG
I tried putting an in-line toggle switch to the DRL wire mentioned in the TSB. I disconnected the Bat and hooked the switch up and this worked great until I went to mount the switch. The location I choose I had to extend the wire. Being in a hurry I did not disconnect the bat this time around (not sure it mattered). So I mounted the switch and lengthend the wire (only a couple inches). Well when I started the truck this time the DRL's wouldn't come on. This got me frustrated because it just worked 2 minutes earlier. I removed the switch and reconnected the wire back to the original configuration and the DRL's did not work again. So mine are permenantly disabled now - even though I wanted the option to turn the DRL's on/off. I've never had my high beam indicator come on though.
Old Aug 29, 2005 | 03:46 PM
  #39
HappyPills's Avatar
Check the fuses.
Old Aug 29, 2005 | 04:04 PM
  #40
KGnagey's Avatar
Check the fuses.
All fuses are good - double checked them. I even pulled the bat cable again for 15 - 20 min to reset the computer. No luck. Is there a DRL relay I'm missing somewhere?
