Differential Capacity?
Old Oct 8, 2003 | 06:33 AM
ugadawg95's Avatar
I am going to tackle this this weekend. I have a 99 4Runner 2wd. Are the rear diff capacities the same on a 2wd and 4wd. I am going to use Amsoil Gear Lube...80W-90 right? Also I am going to get a tranny flush soon...anyone in the Atlanta area had this done, if so any reccomendations on shops to take my vehicle to?
Old Oct 8, 2003 | 07:21 AM
CTB's Avatar
CTB
Just check your owner's manual for differential gear oil capacity and weight. I use 75W-90 in mine, but 80W-90 should work just fine. If I remember right, its takes about 2.5 qts, but don't quote me. Just look it up - it will be in your manual.
Old Oct 8, 2003 | 07:26 AM
growinseed's Avatar
Make sure to open the fill plug before you drain the fluid. It's no fun at all filling through the breather or other location. Just a reminder if you know this already
Nathan
Old Oct 8, 2003 | 07:39 AM
ugadawg95's Avatar
Thanks Nathan! Now I just am going to order the Amsoil and give it a try...
justdifferentials
14
Jun 11, 2017 08:36 PM
shooter86314
Jan 7, 2016 07:05 AM
voiddweller
Oct 2, 2015 07:47 AM
Odin
Sep 26, 2015 06:56 PM
Jake28296
Sep 16, 2015 06:10 AM
