Diff lock disables abs?
Old Nov 30, 2006 | 12:15 AM
mdh's Avatar
mdh
I just completed the diff lock mod and I just noticed the abs light stays on when the lock is on. I searched and found one person stating that whent the locker is engaged it will disable the abs system. Is this true? If it is so what is the reason?
Matt
Old Nov 30, 2006 | 11:06 AM
SteveO's Avatar
Don't know what type of rig you have, but on my '99 4Runner Limited, V6 with the factory locker, yes, this happens.
Old Nov 30, 2006 | 01:07 PM
Elton's Avatar
yes it does disables it not sure why haveint learned that yet
Old Nov 30, 2006 | 01:13 PM
paxil4x4's Avatar
Drama Queen/Banned
It's because with the diff locked both wheels turn at the same speed, and the ABS system is 4 channel one senser per wheel.
Old Nov 30, 2006 | 06:13 PM
Maj's Avatar
Maj
Most 4WD systems disengage the ABS when in 4-low due to ABS not working so great when going down very slippery hills. The ABS can become confused at low speed if all 4 wheels are skidding and in extreme cases will not allow the vehicle to stop. The e-locker mod probably makes the computer think the vehicle is in 4-low and thus disables the ABS.
Old Nov 30, 2006 | 07:11 PM
d0ubledown's Avatar
elocker mod or not, it disables ABS. mr owners manual says so. i think since abs relies on independant wheel speed, it cant control the individual rear corner's brakes since theyre locked (continuously turning at the same speed)..
Old Nov 30, 2006 | 07:31 PM
toyota_mdt_tech's Avatar
Matt
Yes, if you think about it, your rig has a 4 channel ABS system, but if both rear wheels are locked together, it cant correctly judge rear wheel speeds as both rear wheels are now locked together? Going around a corner locked would set off the ABS.
HaukurU
Aug 3, 2015 02:40 PM
dfarr67
Jul 30, 2015 07:08 AM
Daneums
Jul 28, 2015 11:57 AM
Athansinis
Jul 27, 2015 08:38 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
