Did the Dollar bill test and Pop Pop Pop - Now What?
Old Dec 27, 2004 | 12:28 PM
MDToy's Avatar
hello - I did the dollar bill test on the exhaust and there was a lot of Popping (constant) pop papop poppop.. What do i do now? My truck is an 85 w/22re 63000 Original miles - I bought it used - Truck has been sitting for a long time. I've already done a tune up (plugs, pcv, rotor, cap, wires) - What should be my next step?
Old Dec 27, 2004 | 12:43 PM
superjoe83's Avatar
did it ever try to suck the bill up to the exhaust pipe
Old Dec 27, 2004 | 12:51 PM
MDToy's Avatar
Yes the bill was being sucked up against the exhaust, thus causing the popping - Is this a sign of MAJOR problems?
Old Dec 27, 2004 | 01:19 PM
superjoe83's Avatar
you either have a burnt exhaust valve or they are out of adjustment, try adjusting the valves first, if that doesn't fix it, then you will need to remove the head and have a valve job done to it
Old Dec 27, 2004 | 02:03 PM
MDToy's Avatar
Thanks SuperJoe83 - I'm totally new at this, but I'll give it a try. I never did anything more that a basic tune up before I bought this truck, but I just recently (with Yotatech's help) replaced the calipers and rotors successfully.
Anything tricks I need to know before I open the valve cover??
Old Dec 27, 2004 | 02:15 PM
Bigblock's Avatar
you need to do a compression test. they should all be about 110 psi.any low cylinders will be your bill sucker.be advised a dead miss will also do that,as in crossed up plug wires.if one cyl does have low comp then check valve clearance. it could be held open or burnt.
Blamalam
Mar 12, 2022 07:34 AM
TACOJO
Nov 27, 2015 05:26 PM
digdug40
Aug 28, 2015 02:24 PM
JUICE222
Aug 21, 2015 05:16 PM
crashburnoveride
Jul 10, 2015 06:39 AM
