Dash on over to Tech
Old Jun 14, 2002 | 01:00 PM
MRael's Avatar
Brian 'butnut' Mikami explains how to renovate your dash in this well illustrated Tech Article just uploaded.
Thanks Brian!
M
Old Jun 14, 2002 | 02:28 PM
NerfHerder-97SR5-'s Avatar
It's there and quite a good article! I was planning on doing some mods to my inst. panel sometime in the future, however, with the addition of this article, will be taking on the project much sooner!.
A couple ?'s butnut...
Did you use any primer before adding the high temp aluminum spray?
And im confused with your turn signal mod. If you subbed out the blue plastic for the green why would you color the bulbs as well? ( It may make more sense once I take it apart myself, if so sorry to ask a stupid ?
Old Jun 14, 2002 | 03:56 PM
Corey's Avatar
Co-Founder/Administrator
Most excellent job there Mark & Brian.
I dig the tech section
If any of you "modsters" out there want to document something you are working on, get in touch with Mr. Tech Mark.
Old Jun 14, 2002 | 04:33 PM
Yoda's Avatar
I'm taking pix even now. Don't know how many others are going to TBI their Chev V8 in their toys.
Doing the before pix.
Also doing a valve adjust and injector cleaning on a 90 4Runner 3.0 V6. Hope to get pix of that too.
Soon to assist (and document) a conversion to EFI of an 87 2.4 PU (to '90 EFI)
David
Old Jun 14, 2002 | 05:04 PM
BTOWN4RUNNER's Avatar
Good work guys! Real nice write up! Looks good and now I want to do some stuff too! I will have to see what I can come up with. Just a ? though. Is the dash setup similar to that of a 2nd gen as the 3rd? Thanks! :beaver:
-Ryan
Old Jun 14, 2002 | 05:06 PM
MRael's Avatar
Sounds good David. I have a few Toyota projects (not problems) I'd like to pay you to help me sort out, but you live too far away! Dang.
M
Old Jun 14, 2002 | 05:44 PM
It's not there anymore? Where did it go!?! Someone stole the write-up! OH NO!! :beaver:
Old Jun 14, 2002 | 07:43 PM
butnut's Avatar
Cool
Big thanks to Mark for making me look good again! Hope this will help you guys get into yer dash's. Hey Nerf, no primer needed. The Hi-temp is self priming. Under the 'glass' it's well protected. On my upper dash and shifter piece it holds up well. It can scratch though...As for the bulbs, incandescent bulbs have a natural yellow glow. Through the blue plastic, yellow + blue looks greenish. The Sharpie acted as a neutalizer being blue. That's why the 'Hyper-white' bulbs look blue, but give a 'white' light. It's the key to getting a true blue color on the turn sigs. Also, I forgot to mention, I sanded the first layer of blue plastic with 400 grit to give a frosted look like the stock green ones. They have a soft glow that looks nice. Feel free to ask me any questions. Hey Ryan, I can't say for sure about the 2nd gen dash. The R&R of your dash should be very similar though...give it a shot and post your findings.
butnut
Old Jun 14, 2002 | 11:58 PM
Good stuff nut, thanks again.
Old Jun 16, 2002 | 02:22 PM
butnut's Avatar
Cool
Here's another painting tip. I spray pieces on the bottom of a slightly larger box. That way I can rotate the piece to spray all the inside angles, nooks etc without touching the piece. On the gauge surround, I also sprayed from behind to cover the lower slots evenly. Don't try to get heavy color coverage too fast. You can tell with this color as it likes to bubble a dark grey if you got too close. Don't worry, give it time to flash dry and it will even out. Respray later, this time stay farther away and build up light coverage. Build light dusting coats and let flash 1 minute between coats. It dries fast so turn, spray, let flash, turn spray etc. Should take about 10 minutes tops, with multiple coats. Don't rush it, and you'll have a very even pro finished piece. Let final spray dry 10 minutes to let the solvents flash out. Good luck.
butnut
Old Jun 26, 2002 | 09:12 AM
HBoss's Avatar
Butnut,
I received the blue plastic slugs in the mail today! Woohoo! Thanks man!
Guess I know what I'm doing this weekend.
Al
Old Jun 26, 2002 | 09:43 AM
Nut I did the dash but couldnt find the right kind of plastic. If you did have any left after sending Boss, e-mail me mate.
Old Jun 26, 2002 | 11:50 AM
butnut's Avatar
Cool
Kool Al...good luck. Email me if you run into any snags. Nerf...Email yer addy to me, I'll make some up for ya.
butnut
Old Jun 26, 2002 | 02:56 PM
Butnut, why type of plastic did you use? I noticed how you used a clear plastic, but what type is it? 1, 2, etc? Just wondering if I ever get the dash apart I can do that! Thanks! :fireman:
Old Jun 26, 2002 | 08:51 PM
butnut's Avatar
Hey Ryan. It's an el-cheapo Japan plastic case. The Tech Article has pics.
butnut
Old Jun 27, 2002 | 01:38 PM
butnut
Alright, very good, thanks alot dude! I will have to add them when someone wisens up and makes the reverse indiglo guages for the 2nd gen. LOL...boy I wish!!! :fireman:
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
toyotasaurus
Sep 24, 2015 03:30 PM
