Cruise Control Fixed on 2cnd gen
Old Aug 2, 2004 | 04:01 PM
Marc's Avatar
I think I may have fixed my cruise controls ability to stay in overdrive.
Thanks to a post by dandeman at 4x4wire.com who had a fix for an older Toyota.
The problem I had and I believe others as well, is that when using the cruise control it often wanted to kick overdrive off in situations where it wasn't warranted - like cruising on level ground (bad cruise).
I cut wire no. 7 (Yellow with a Red Stripe) coming out of the CC ECU in the left kick panel. My wiring diagram indicated that this wire on CANADIAN vehicles was involved with the O/D relay.
I have since completed 3 - 200 mile trips and the cruise worked as it should. It still kicks overdrive out, but only going up hills. It works the same as if I was using my foot on the throttle. I have thought I'd fixed it before and it worked well for a few trips but I'm hoping this is the real cure.
disclaimer - I really have no idea what I'm doing so I don't know if this will have any negative impact on my transmission or will work on other years-models- or country of origin
coryc85
Sep 9, 2015 06:24 AM
jake_v
Jul 22, 2015 03:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
sojourner567
Jul 16, 2015 08:52 PM
voiddweller
Jul 15, 2015 03:56 PM
