Cross Country readiness
Old Feb 21, 2005 | 08:37 PM
Cardesign's Avatar
My NY to CA drive will begin on monday. here is what has been I have performed myself on the truck since I bought it three weeks ago. Chime in If I forgot anything.
98 SR5 4WD
replace fuel filter
air filter
plugs
clean maf
oil
2 tranny drain and refills with mobil 1
mobil 1 in TC
degrease engine
brembo/PF pad upgrade
rear brake adjustment (brake spoon)
balance and rotation
new antenna (need tunes for week of driving)
Old Feb 21, 2005 | 08:48 PM
AUJWE
Guest
Posts: n/a
Clean throttle body, replace PCV valve?
Old Feb 21, 2005 | 09:05 PM
Morphine's Avatar
What part of CA??
Whats the cause for the cross country trip? What part of CA you going to? Maybe, if close enough and I haven't left for Idaho yet, a few of us can get together?? Just a thought.
-=Morphine=-
Old Feb 22, 2005 | 03:33 AM
Ilovemountains's Avatar
too late now but..
98 SR5 4WD
replace fuel filter
air filter
plugs
clean maf
oil
mobil 1 in TC
degrease engine
I guess its too late now but if it was me I would have changed the cap, rotor and wires along with the plugs and would have made sure my antifreeze was OK, I probably would have just changed it! I would also change my rear diff fluid again, just because it is starting to howl a little, it would suck to be 2000 miles from home and have a break down......
Old Feb 22, 2005 | 04:31 AM
Cardesign's Avatar
antifreeze is good. Im moving out to CA to go back to school and want to get into the automotive industry.
Old Feb 22, 2005 | 04:47 AM
85badger's Avatar
Its a Toyota............jump in it and go!!!
Old Feb 22, 2005 | 09:56 AM
CappyKD's Avatar
I would still replace the antifreeze and thermostat as well as change both Diff fluids and Tranny and T/C (I think you did those last 2). I would also consider changing the wiper blades, Cap, Rotor and plug wires.
Old Feb 22, 2005 | 10:07 AM
Cardesign's Avatar
wipers are def changed and I polished the glass to remove that annoying road film on it. The truck only has 77k on it so im pretty sure that the plug wires, cap and rotor are good. Shes running nice (knock on wood). Im more worried about gettign a flat and having to deal with that useless factory jack. AAA will have to rescue me then.
Correction...the drive begins tommorow (wednesday) not monday.
Old Feb 22, 2005 | 10:44 AM
getitdone's Avatar
what are you going to do in the automotive industry?
also, what do you go to school for?
Old Feb 22, 2005 | 11:09 AM
4-RUNNIN' FREAK's Avatar
Throw some solid blocks of wood somewhere just in case you need a little extra lift.
Old Feb 22, 2005 | 12:26 PM
AUJWE
Guest
Posts: n/a
Well you don't have a cap and rotor so don't worry about that. But, if you have 77K on the origional plugs and or wires then they could definitely use changing. Do the PCV valve while you are at it, it's cheap.
Old Feb 22, 2005 | 12:46 PM
lee's Avatar
lee
bring along some fix-a-flat too!
Old Feb 22, 2005 | 01:29 PM
Cardesign's Avatar
goign to school for automotive design at Art Center in Pasadena. I want to work in a shop a bit before school. Hot rod or custom shop. PLugs are new and got the fix a flat too. Just loaded her up. Shes saggin a bit in the back but thats expected with all the weight. The springs are a week old so I guess they'll bounce back nice.
ToyotaMD
Nov 9, 2015 11:53 AM
voiddweller
Oct 2, 2015 07:47 AM
ktm192k
Oct 1, 2015 08:47 AM
mordell
Sep 12, 2015 10:13 AM
